Grooveshark country null error
jamesattard
I am getting the following error after I try to do the search (I go to the song folder, enter inside each folder to search, following your instructions, then go to the top folder (which stays -) and still getting no results:
Private debug started
Gs 0.39 using path /home/james/.config/UMS/data/gs/ tiny mode false init delay 0
Grooveshark country "country":null
exceptiuon java.lang.NullPointerException
FYI, I can access grooveshark from the webbrowser.
- SharkHunter
- Developer
Re: Grooveshark country null error
Version 0.39 is old. Very old. You should have the latest version which should be 0.55
https://code.google.com/p/sharkhunter-s ... r&can=2&q=
