Roku and Xbox Access
My Xboxes and Rokus used to be able to see my Windows computer with Universal Media Server on it. Lately they keep saying they can't find any DLNA media server. I have completely uninstalled UMS and re-installed with a clean install. Still can't see it on the network. I have verified that I can get to the server from my laptop by using a browser and inputting the IP:9001 and I can see all my movies and such. I have the firewall completely turned off on the "server" computer. What am I missing? I set UMS up to not require any user authentication or anything like that.
Re: Roku and Xbox Access
Here are my log files
- _ums_dbg_2023-03-22-15-53.zip
- (1.2 MiB) Downloaded 391 times
I had a quick look at your logs and can see there is plenty of communication with the Xbox, same for the Rokus.
I know little about the communication protocols so I don't know if there is a problem here or what to look for.
I did see some warnings from the Rokus though where UMS cannot find a file on them but I don't know if this has anything to do with it.
This is something the Devs will need a look to see what is happening.
Only thing I can think of is something in your router may be stopping some of the communication.
Your LG TV has no problems from what I can see, are the Rokus and Xbox connected wirelessly, and your TV wired?
WARN 2023-03-22 15:51:53.520 [jupnp-async-protocol-16] org.jupnp.protocol.RetrieveRemoteDescriptors Service descriptor retrieval failed: http://192.168.50.124:8060/dial/dial_SCPD.xml, 404 Not Found
WARN 2023-03-22 15:51:53.521 [jupnp-async-protocol-16] org.jupnp.protocol.RetrieveRemoteDescriptors Device service description failed: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:28001000-0000-1000-8000-20efbd9b105b, Descriptor: http://192.168.50.124:8060/dial/dd.xml, Root: true
WARN 2023-03-22 15:51:53.941 [jupnp-async-protocol-10] org.jupnp.protocol.RetrieveRemoteDescriptors Service descriptor retrieval failed: http://192.168.50.223:8060/dial/dial_SCPD.xml, 404 Not Found
WARN 2023-03-22 15:51:53.942 [jupnp-async-protocol-10] org.jupnp.protocol.RetrieveRemoteDescriptors Device service description failed: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:29880009-a000-101f-8048-88dea92ea451, Descriptor: http://192.168.50.223:8060/dial/dd.xml, Root: true
