Java issue when operating UMS on a high CPU
Re: Java issue when operating UMS on a high CPU
Will need to see logs to know exactly what is happening (see the section in red above), but it is normal for UMS to use a lot of CPU when scanning your media.
If you have an extensive media library this can take a while but once everything is scanned it should return to normal and not need to do it again.
Any changes to your media files will then only take seconds to scan.
If you just upgraded to a newer version or your database was corrupt then this might be what triggered the scan if you did not do it yourself.
UMS should still quit when you want it too. How did you try and quit, the old interface or the web based one? Did you try right clicking the tray icon and selecting quit?
