[Solved] UMS 13.8.0 wont start on macOS Sonoma 14.2.1
Java is installed and updated
full rights to drive enabled
Error: "UMS" can't be opened because Apple can't check for malware.
Re: UMS 13.8.0 wont start on macOS Sonoma 14.2.1
Can you please attach a screenshot of the error?
screens attached
- Snímek obrazovky 2023-12-27 v 22.16.11.png (269.1 KiB) Viewed 4426 times
- Snímek obrazovky 2023-12-27 v 22.16.36.png (852.83 KiB) Viewed 4426 times
It seems Apple keeps changing their requirements...
They have an article about how to get around that at https://support.apple.com/en-nz/guide/m ... b3a043/mac
Please let me know if that works
Also since you are on an M1 mac, please make sure you are using our ARM release, https://github.com/UniversalMediaServer ... .0-arm.dmg
Thank you, this helped and it works correctly now!
Thank you for your help!
Michal
Michal
