Fastforward - Rewind for Xbox360
I noticed the Xbox360 has rewind and fast forward capabilities. I did some research and found that some other clients allow for this fastforward rewind function work. Since this is now a universal media player and the Xbox is now officially supported, I was wondering if someone could look into the issue in their spare time as I lack the advanced coding skills required in such a matter. Just an idea.
Re: Fastforward - Rewind for Xbox360
Will definitely look into it, thanks for the suggestion
This is a great suggestion but the function actually works on the XBox but with a caveat. It works with only certain encodings. I usually play AVIs bun sometimes FFW/RWD works and other times it doesn't depending on the coding.
Let's get rid of the caveat then. Last time I checked USMS can transcodecmonster wrote:This is a great suggestion but the function actually works on the XBox but with a caveat. It works with only certain encodings. I usually play AVIs bun sometimes FFW/RWD works and other times it doesn't depending on the coding.
Has there been any progress on this feature?
Stirring up an old thread.
Has any progress been made on this feature. I am playing MKVs on an XBOX 360 (which is awesome) but fast forward or rewind causes erratic behavior if it works at all.
Any information on this would be great.
