Folder sorting not right. With version 14.2.0
I have the sorting on By display name. in version 14.1.0 the sorting was good, but in version 14.2.0 some folders are good some not or you see them twice.
Re: Folder sorting not right. With version 14.2.0
This has been reported to happen in 14.2.1 too.
It has been fixed and will be in the next version. I think Patreons have access to this fix now.
Thanks for reporting this, if you let me know your operating system I can upload a fixed build for you
I have the same problem. The sorting is generally alphabetic backwards but not totally consistently.
I've reverted to 13.10.0 which doesn;t have this problem.
Also found that 14.2.0 doesn't list all folders, whereas 13.10.0 does.
I'm running Windows 10.
Well it fixed for me in 14.2.1.
