i know im not this dumb... but please help
i have ben a advid used of UMS for many years, i have had problems here and there that i have read on how to fix or figured out "how to" get working again. i bring this problem...
all ( 5) of my smart tv's using UMS will run flawlessly at any given time. but lately and now (even before a update of most recent) i can NOT get the UMS to rum without restarting computer, mutiple times, refreshing the desired tv that im infront of . and in some combanations of just back and forth of turning of and on of both, unplugging even rebooting the router. if it matters.. 2 samsung 2 LG. the common problem is... it will see the mediea server icon on the TV, it will load the drive, then will show "no content found" i can say that as of a few months ago i used the 1 computer that had 3 USB drives conected to it and also used a 2nd computer that was networked with 3 other USB drives with NO sharing or lagging problems what so ever.
this debug file that i belive that i have sent here is where i restarted my computer, restarted my tv let UMS log in , turned tv on , went to UMS icon, opened it navigate to selection, it opens and then tv goes into network trouble shoot test. BUT it will let me still navigate threw all the folders and files, just not play one
windows computer - SMB-2023-0
Processor Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz 3.41 GHz
Installed RAM 31.9 GB
System type 64-bit operating system, x64-based processor
netgear nighthawk RAX50v2
i hope that i did this right, and i hope that i gave enough information to help !!!
UMSLog (1).txt- (8.04 KiB) Downloaded 802 times
Re: i know im not this dumb... but please help
Please post your full logs as those are of no help. See the red section above.
When you say you cannot get UMS to run without restarting do you mean that it is not showing on your TV till you reboot or the actual program is not running on the computer?
Can you access the web interface and does it show your TVs?
Did anything change when this started to happen? Did something update like UMS, Windows, router or antivirus?
to the best of my non computer ability .. i will have the UMS up and running on my computer (never shuts down unless updating or rebooting) my TV's will sometimes not see UMS on the network. i will then go to the computer and restart the UMS and then the TV's will now be able to view and browse what is on the computer... BUT 98% of the time especially now, i will go to open a movie/show and it will be "no content found". as i now back up threw the folders that got me to that point of movie/show, it displays "no content found" .. this is where i restart the UMS and try again. sometimes this helps. but just maybe on the ONE TV that im in front of at this moment. hopefully i can give the information that is needed to understand. i did learn a while ago from reading in these posts that the cheap TV's from walmart were not able to run the UMS properly so i did make sure that i now only have samsung and LG TV's being used if that matters at all
i'm hopefull my attempt at the log file works this time..
after now "opening" the log file before i send it .. i see that its completely useless for what anyone would need to diagnosis anything... the log file that im seeing that is happening as i try on the TV in front of me is completly different then what is ziped and sent... if i thought that i was dumb before....
- ums_dbg_2024-12-14-10-15.zip
- (345.15 KiB) Downloaded 759 times
11:14:06 INFO : Windows Media Player
11:14:06 INFO : XBMC
11:14:06 INFO : Xbox 360
11:14:06 INFO : Yamaha AV Receiver
11:14:06 INFO Checking the fontconfig cache in the background, this can take two minutes or so.
11:14:07 INFO Configuration saved to "C:\ProgramData\UMS\UMS.conf"
11:14:07 INFO Found AviSynth FFmpegSource2 library
11:14:07 INFO Found AviSynth DirectShowSource library
11:14:07 INFO Found AviSynth mvtools2 library
11:14:07 INFO Found AviSynth Depan library
11:14:07 INFO Found AviSynth masktools2 library
11:14:07 INFO Found AviSynth CropResize script
11:14:07 INFO Found AviSynth convert2dTo3d script
11:14:07 INFO Transcoding engine "AviSynth/FFmpeg" is available
11:14:07 INFO Transcoding engine "AviSynth/MEncoder" is available
11:14:07 INFO Transcoding engine "FFmpeg Audio" is available
11:14:07 INFO Transcoding engine "MEncoder Video" is available
11:14:07 INFO Transcoding engine "FFmpeg Video" is available
11:14:07 WARN Transcoding engine "VLC Video" is not available
11:14:07 INFO Transcoding engine "FFmpeg HLS Video" is available
11:14:07 INFO Transcoding engine "FFmpeg Web Video" is available
11:14:07 INFO Transcoding engine "MEncoder Web Video" is available
11:14:07 WARN Transcoding engine "VLC Web Video" is not available
11:14:07 INFO Transcoding engine "tsMuxeR Video" is available
11:14:07 INFO Transcoding engine "tsMuxeR Audio" is available
11:14:07 WARN Transcoding engine "VLC Web Audio (Legacy)" is not available
11:14:07 WARN Transcoding engine "VLC Web Video (Legacy)" is not available
11:14:08 INFO Transcoding engine "DCRaw" is available
11:14:08 INFO Transcoding engine "youtube-dl" is available
11:14:08 INFO Using the following UUID configured in UMS.conf: 02360117-4eab-4dda-a174-33fabb745fff
11:14:08 INFO Registering UPnP servlet under context path:
11:14:08 INFO Starting Jetty server 12.0.14
11:14:08 INFO Starting Jetty HTTP client v12.0.14 connection manager/pool
11:14:08 INFO IP Filter: Access allowed to SMB-2023-0
11:14:09 INFO Web player is available at: http://192.168.1.18:9002
11:14:09 INFO Universal Media Server is now available for renderers to find
11:14:09 INFO Launching the graphical interface on a browser
11:14:13 INFO IP Filter: Access allowed to 192.168.1.22
11:14:13 INFO IP Filter: Access allowed to SEANXI
11:14:13 INFO Finding user id: -1
11:14:13 INFO Checking IP: 192.168.1.20 for UnknownRenderer
11:14:13 INFO Renderer UnknownRenderer found on address: SEANXI (192.168.1.20)
11:14:13 INFO IP Filter: Access allowed to JENSOFFICECOMPU
11:14:13 INFO Media renderer was not recognized. Possible identifying HTTP headers:
User-Agent: DAFUPnP
Pragma: no-cache
Cache-control: no-cache
11:14:13 INFO Checking IP: 192.168.1.13 for UnknownRenderer
11:14:13 INFO Renderer UnknownRenderer found on address: JENSOFFICECOMPU (192.168.1.13)
11:14:13 INFO Checking IP: 192.168.1.22 for Samsung CU7000 65
11:14:13 WARN Renderer icon "http://192.168.1.22:9197/icon_LRG.jpg" is not sized correctly
11:14:13 INFO Finding user id: 1
11:14:18 INFO IP Filter: Access allowed to 192.168.1.9
11:14:18 INFO Finding user id: -1
11:14:18 INFO Checking IP: 192.168.1.9 for LG WebOS TV
11:14:18 INFO Media renderer was not recognized. Possible identifying HTTP headers:
User-Agent: DAFUPnP
Pragma: no-cache
11:14:18 INFO Renderer Samsung CU7000 65 found on address: 192.168.1.22
11:14:22 INFO IP Filter: Access allowed to 192.168.1.19
11:14:22 INFO Finding user id: -1
11:14:22 INFO Renderer LG WebOS TV found on address: 192.168.1.9
11:14:22 INFO Checking IP: 192.168.1.19 for UnknownRenderer
11:14:22 INFO Media renderer was not recognized. Possible identifying HTTP headers:
User-Agent: DLNADOC/1.50 SEC_HHP_50" Crystal UHD/1.0 UPnP/1.0
User-Agent: DLNADOC/1.50 SEC_HHP_Samsung CU7000 65/1.0 UPnP/1.0
11:14:22 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:14:22 WARN Renderer icon "http://192.168.1.22:9197/icon_LRG.jpg" is not sized correctly
11:14:23 INFO Finding user id: -1
11:14:27 INFO IP Filter: Access allowed to 192.168.1.1
11:14:27 INFO Listing all users
11:14:27 INFO Renderer UnknownRenderer found on address: 192.168.1.19
11:14:27 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:14:28 INFO Finding user id: -1
11:14:28 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:14:28 INFO Renderer UnknownRenderer has an estimated network speed of 350.74048 Mb/s
11:14:28 INFO Renderer UnknownRenderer has an estimated network speed of 9.949660504201681 Mb/s
11:14:33 INFO Renderer Samsung CU7000 65 has an estimated network speed of 68.64609882352941 Mb/s
11:14:37 INFO Renderer LG WebOS TV has an estimated network speed of 66.25496470588236 Mb/s
11:14:42 INFO Renderer UnknownRenderer has an estimated network speed of 67.37504 Mb/s
11:14:47 INFO Finding user id: -1
11:14:47 INFO Checking IP: 192.168.1.1 for UnknownRenderer
11:14:52 INFO Renderer UnknownRenderer found on address: 192.168.1.1
11:15:07 INFO Renderer UnknownRenderer has an estimated network speed of 105.52769523809523 Mb/s
11:21:29 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:21:30 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:21:31 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:21:32 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:21:33 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:21:34 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:21:35 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:21:36 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:21:37 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:26:08 INFO Media renderer was not recognized. Possible identifying HTTP headers:
Soapaction: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
11:26:08 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:26:10 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:26:10 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:26:11 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:26:11 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:26:12 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:26:12 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:26:28 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:26:28 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:26:33 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:26:33 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:26:38 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:26:38 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:26:40 INFO Started playing FBI.S07E07.480p.x264-RUBiK.mkv (No transcoding) on your 50" Crystal UHD
11:26:41 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:26:41 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:26:52 INFO Media renderer was not recognized. Possible identifying HTTP headers:
Soapaction: "urn:schemas-upnp-org:service:ContentDirectory:1#X_SetBookmark"
11:26:52 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:26:54 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:26:54 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:26:59 INFO Stopped playing FBI.S07E07.480p.x264-RUBiK.mkv on 50" Crystal UHD
11:26:59 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:26:59 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:27:23 INFO IP Filter: Access allowed to 192.168.1.8
11:27:23 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:27:23 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:27:27 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:27:27 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:27:28 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:27:28 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:27:30 INFO Started playing Star.Wars.Skeleton.Crew.S01E02.1080p.x265-ELiTE.mkv (FFmpeg Video) on your 50" Crystal UHD
11:27:33 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:27:33 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:27:40 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:27:42 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:27:43 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:27:45 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:27:46 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:27:48 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:28:53 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:28:54 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:28:55 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:28:56 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:28:57 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:28:58 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:28:59 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:29:00 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:29:02 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:29:37 INFO Media renderer was not recognized. Possible identifying HTTP headers:
11:29:37 WARN Renderer icon "http://192.168.1.19:9197/icon_LRG.jpg" is not sized correctly
11:30:55 INFO Finding user id: -1
11:30:55 INFO Checking IP: 192.168.1.18 for UnknownRenderer
11:30:55 INFO Renderer UnknownRenderer found on address: SMB-2023-0 (192.168.1.18)
11:31:10 INFO Renderer UnknownRenderer has an estimated network speed of 700.7744 Mb/s
11:36:17 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
11:36:18 INFO [Fatal Error] :1:10: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
[size=50][/size]
- debug.log.prev[1].zip
- (4.05 MiB) Downloaded 768 times
The prev logs were included in the zip file. Posting the raw logs on the forum causes it to trigger the spam filter (one of the few thing that does) and withhold the post.
From what I can see with a quick look there are no errors and is working as it should. There are a few warnings that are normal and can be ignored.
I can see it is detecting your LG TVs (192.168.1.9 and 192.168.1.19) but nothing to do with Samsung.
Were they on? What are the IPs of these? I did see speed tests on several unknown renderers so these may have been Samsung but are not being detected
I assume the LGs work properly as I can see something being played.
From what I get from your post UMS is not showing on your TVs when you turn them on.
It may be that it can take a few mins for UMS to discover them depending on how frequently they advertise their presence on the network.
I think in the past UMS would spam its presence on the network but was changed to be more passive in listening to prevent network congestion.
I know sometimes it can take a short while for my PS4 to be discovered.
If you check the web interface you will be able to see if UMS detects them like this. No need to reboot the computer if it does not show. If it does not appear after a few mins then it could be a problem with your network setup and something is blocking traffic to them.
How is your network set up? Is it wired or wifi? Do you have multiple routers or wifi extenders?
