Problem with working UMS on win8.1 64bit
sapsa
Post by sapsa »
Sometimes is does work, sometimes it dosen't
Default setting, only ignored one render.conf for comaptibilty with tv.
Before this tsMuxer.exe crashed
I saw few errors before that ums tried to run/mount? iso from same folder with game when i was trying to play a movie, so I just moved the move to 'new folder' and added it to shears. Sometimes it dose work, more of the time it doesn't
DEBUG 2014-02-22 21:56:14.518 [main] Reading cred.path: default: "", current: "C:\ProgramData\UMS\UMS.cred"
DEBUG 2014-02-22 21:56:14.527 [main] Reading run_wizard: default: true, current: false
INFO  2014-02-22 21:56:14.527 [main] Starting Universal Media Server 3.4.1
INFO  2014-02-22 21:56:14.527 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO  2014-02-22 21:56:14.527 [main] http://www.universalmediaserver.com
INFO  2014-02-22 21:56:14.528 [main]
INFO  2014-02-22 21:56:14.528 [main] Build: 825a9eb7c (2014-02-14)
INFO  2014-02-22 21:56:14.528 [main] Java: Java HotSpot(TM) 64-Bit Server VM 1.7.0_51 64-bit by Oracle Corporation
INFO  2014-02-22 21:56:14.528 [main] OS: Windows 8 64-bit 6.2
INFO  2014-02-22 21:56:14.528 [main] Encoding: UTF-8
INFO  2014-02-22 21:56:14.535 [main] Memory: 1138 MB
INFO  2014-02-22 21:56:14.536 [main] Language: pl
INFO  2014-02-22 21:56:14.536 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2014-02-22 21:56:14.537 [main] Temp directory: C:\Users\sapsa\AppData\Local\Temp\universalmediaserver
INFO  2014-02-22 21:56:14.537 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2014-02-22 21:56:14.538 [main] debug.log: C:\ProgramData\UMS\debug.log
INFO  2014-02-22 21:56:14.538 [main] Profile directory: C:\ProgramData\UMS
INFO  2014-02-22 21:56:14.539 [main] Profile directory permissions: rw
INFO  2014-02-22 21:56:14.539 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2014-02-22 21:56:14.539 [main] Profile permissions: rw
INFO  2014-02-22 21:56:14.539 [main] Profile name: blackbox
INFO  2014-02-22 21:56:14.540 [main]
INFO  2014-02-22 21:56:14.540 [main] Web conf path: C:\ProgramData\UMS\WEB.conf
INFO  2014-02-22 21:56:14.540 [main] Web conf permissions: rw
DEBUG 2014-02-22 21:56:14.794 [main] Reading hide_advanced_options: default: true, current: false
DEBUG 2014-02-22 21:56:14.838 [main] Reading maximum_bitrate: default: "110", current: "0"
DEBUG 2014-02-22 21:56:15.408 [main] Reading folders: default: "", current: "D:\New Folder"
INFO  2014-02-22 21:56:15.408 [main] Checking shared folder: D:\New Folder
INFO  2014-02-22 21:56:15.674 [main] Loading MediaInfo library
INFO  2014-02-22 21:56:15.738 [main] Loaded MediaInfoLib - v0.7.66
INFO  2014-02-22 21:56:15.741 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
DEBUG 2014-02-22 21:56:15.744 [main] Reading ignored_renderers: default: "", current: "LG 42LA644V,"
INFO  2014-02-22 21:56:15.744 [main] Loaded configuration for renderer: AirPlayer
INFO  2014-02-22 21:56:15.746 [main] Loaded configuration for renderer: Android
INFO  2014-02-22 21:56:15.749 [main] Loaded configuration for renderer: KalemSoft Media Player
INFO  2014-02-22 21:56:15.751 [main] Loaded configuration for renderer: Sony Bravia 4500
INFO  2014-02-22 21:56:15.753 [main] Loaded configuration for renderer: Sony Bravia 5500
INFO  2014-02-22 21:56:15.756 [main] Loaded configuration for renderer: Sony Bravia EX
INFO  2014-02-22 21:56:15.759 [main] Loaded configuration for renderer: Sony Bravia EX620
INFO  2014-02-22 21:56:15.762 [main] Loaded configuration for renderer: Sony Bravia HX
INFO  2014-02-22 21:56:15.765 [main] Loaded configuration for renderer: Sony Bravia W6/W8/W9
INFO  2014-02-22 21:56:15.767 [main] Loaded configuration for renderer: DirecTV HR
INFO  2014-02-22 21:56:15.769 [main] Loaded configuration for renderer: D-Link DSM-510
INFO  2014-02-22 21:56:15.771 [main] Loaded configuration for renderer: Freebox HD
INFO  2014-02-22 21:56:15.773 [main] Loaded configuration for renderer: Freecom MusicPal
INFO  2014-02-22 21:56:15.775 [main] Loaded configuration for renderer: iPad / iPhone
INFO  2014-02-22 21:56:15.777 [main] Loaded configuration for renderer: Pioneer Kuro
DEBUG 2014-02-22 21:56:15.780 [main] Ignored LG 42LA644V configuration
INFO  2014-02-22 21:56:15.782 [main] Loaded configuration for renderer: LG Smart TV Upgrader
INFO  2014-02-22 21:56:15.783 [main] Loaded configuration for renderer: Nokia N900
INFO  2014-02-22 21:56:15.785 [main] Loaded configuration for renderer: Netgear NeoTV
INFO  2014-02-22 21:56:15.786 [main] Loaded configuration for renderer: Onkyo TX-NR717
INFO  2014-02-22 21:56:15.788 [main] Loaded configuration for renderer: OPPO BDP-83
INFO  2014-02-22 21:56:15.789 [main] Loaded configuration for renderer: OPPO BDP-93
INFO  2014-02-22 21:56:15.791 [main] Loaded configuration for renderer: Panasonic TV
INFO  2014-02-22 21:56:15.793 [main] Loaded configuration for renderer: Panasonic TX-L32V10E
INFO  2014-02-22 21:56:15.794 [main] Loaded configuration for renderer: Philips Aurea
INFO  2014-02-22 21:56:15.797 [main] Loaded configuration for renderer: Philips TV
INFO  2014-02-22 21:56:15.798 [main] Loaded configuration for renderer: Popcorn Hour
INFO  2014-02-22 21:56:15.801 [main] Loaded configuration for renderer: PlayStation 3
INFO  2014-02-22 21:56:15.803 [main] Loaded configuration for renderer: Realtek
INFO  2014-02-22 21:56:15.805 [main] Loaded configuration for renderer: Samsung SMT-G7400
INFO  2014-02-22 21:56:15.806 [main] Loaded configuration for renderer: Samsung D7000
INFO  2014-02-22 21:56:15.807 [main] Loaded configuration for renderer: Samsung AllShare
INFO  2014-02-22 21:56:15.809 [main] Loaded configuration for renderer: Samsung Mobile
INFO  2014-02-22 21:56:15.810 [main] Loaded configuration for renderer: Samsung WiseLink
INFO  2014-02-22 21:56:15.811 [main] Loaded configuration for renderer: Sharp Aquos
INFO  2014-02-22 21:56:15.813 [main] Loaded configuration for renderer: Showtime 3
INFO  2014-02-22 21:56:15.815 [main] Loaded configuration for renderer: Showtime 4
INFO  2014-02-22 21:56:15.817 [main] Loaded configuration for renderer: Sony SMP-N100
INFO  2014-02-22 21:56:15.819 [main] Loaded configuration for renderer: Sony Blu-ray
INFO  2014-02-22 21:56:15.821 [main] Loaded configuration for renderer: Sony Home Theatre System
INFO  2014-02-22 21:56:15.823 [main] Loaded configuration for renderer: Sony STR-DA5800ES
INFO  2014-02-22 21:56:15.824 [main] Loaded configuration for renderer: Streamium
INFO  2014-02-22 21:56:15.825 [main] Loaded configuration for renderer: Telstra T-Box
INFO  2014-02-22 21:56:15.826 [main] Loaded configuration for renderer: VideoWeb TV
INFO  2014-02-22 21:56:15.828 [main] Loaded configuration for renderer: Vizio Smart TV
INFO  2014-02-22 21:56:15.830 [main] Loaded configuration for renderer: WD TV Live
INFO  2014-02-22 21:56:15.831 [main] Loaded configuration for renderer: WMP
INFO  2014-02-22 21:56:15.832 [main] Loaded configuration for renderer: XBMC
INFO  2014-02-22 21:56:15.834 [main] Loaded configuration for renderer: Xbox 360
INFO  2014-02-22 21:56:15.835 [main] Loaded configuration for renderer: Yamaha RX-A1010
INFO  2014-02-22 21:56:15.836 [main] Loaded configuration for renderer: Yamaha RX-V3900
INFO  2014-02-22 21:56:15.837 [main] Loaded configuration for renderer: Yamaha RX-V671
INFO  2014-02-22 21:56:15.837 [main] Checking the fontconfig cache, this can take two minutes or so.
DEBUG 2014-02-22 21:56:15.841 [mplayer.exe-0] Starting "C:\Program Files (x86)\Universal Media Server\win32\mplayer.exe" dummy
DEBUG 2014-02-22 21:56:15.847 [main] AviSynth plugins directory: C:\Program Files (x86)\AviSynth\plugins
INFO  2014-02-22 21:56:15.847 [main] VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
INFO  2014-02-22 21:56:15.852 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2014-02-22 21:56:15.854 [main] No plugins found
DEBUG 2014-02-22 21:56:15.856 [mplayer.exe-0] Attaching thread: mplayer.exe-0
INFO  2014-02-22 21:56:15.864 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2014-02-22 21:56:15.865 [main] Registering transcoding engine: FFmpeg Audio
INFO  2014-02-22 21:56:15.868 [main] Registering transcoding engine: MEncoder
INFO  2014-02-22 21:56:15.869 [main] Registering transcoding engine: AviSynth/MEncoder
INFO  2014-02-22 21:56:15.869 [main] Registering transcoding engine: FFmpeg
INFO  2014-02-22 21:56:15.871 [main] Executable of transcoder profile VLC not found
DEBUG 2014-02-22 21:56:15.873 [Thread-8] File not found: 'dummy'
DEBUG 2014-02-22 21:56:15.873 [Thread-8] Failed to open dummy.
DEBUG 2014-02-22 21:56:15.892 [main] FFmpeg supported protocols: [bluray, cache, concat, crypto, data, file, ftp, gopher, hls, http, httpproxy, https, mmsh, mmst, pipe, rtp, srtp, tcp, tls, udp, rtmp, rtmpe, rtmps, rtmpt, rtmpte, mms]
INFO  2014-02-22 21:56:15.892 [main] Registering transcoding engine: FFmpeg Web Video
INFO  2014-02-22 21:56:15.893 [main] Registering transcoding engine: MEncoder Web
INFO  2014-02-22 21:56:15.893 [main] Executable of transcoder profile VLC Web Video not found
INFO  2014-02-22 21:56:15.894 [main] Registering transcoding engine: tsMuxeR
INFO  2014-02-22 21:56:15.895 [main] Registering transcoding engine: Audio High Fidelity
INFO  2014-02-22 21:56:15.895 [main] Executable of transcoder profile VLC Web Audio (Legacy) not found
INFO  2014-02-22 21:56:15.896 [main] Executable of transcoder profile VLC Web Video (Legacy) not found
INFO  2014-02-22 21:56:15.896 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2014-02-22 21:56:15.897 [main] Registering transcoding engine: dcraw Thumbnailer
DEBUG 2014-02-22 21:56:15.932 [main] Reading alternativeffmpegpath: default: null, current: "C:\Program Files (x86)\Universal Media Server\win32\dvrms\ffmpeg_MPGMUX.exe"
DEBUG 2014-02-22 21:56:15.939 [main] Reading avisynth_script: default: "<movie>
<sub>
", current: "<movie>
<sub>"
INFO  2014-02-22 21:56:15.952 [main] Using address /10.1.1.18 found on network interface: name:eth1 (Realtek PCIe GBE Family Controller)
INFO  2014-02-22 21:56:15.952 [main] Created socket: /10.1.1.18:5001
DEBUG 2014-02-22 21:56:16.027 [main] Sending ALIVE...
DEBUG 2014-02-22 21:56:16.056 [main] Reading uuid: default: null, current: "16547c31-0673-42f6-8d91-b793003badd7"
INFO  2014-02-22 21:56:16.056 [main] Using the following UUID configured in UMS.conf: 16547c31-0673-42f6-8d91-b793003badd7
INFO  2014-02-22 21:56:16.311 [main] The server is now available for renderers to find
INFO  2014-02-22 21:56:16.804 [New I/O worker #1] No IP filter specified, access granted to /10.1.1.8
DEBUG 2014-02-22 21:56:16.809 [New I/O worker #2] HTTP User-Agent: Showtime PS3 4.5.87.g59e59.dirty
INFO  2014-02-22 21:56:16.809 [pool-6-thread-1] Checking IP: 10.1.1.8 for Showtime 4
DEBUG 2014-02-22 21:56:16.813 [New I/O worker #2] master is internal:net.pms.dlna.RealFile str Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv>D:\New Folder\Mononoke hime - Princess Mononoke (1997)\Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv
DEBUG 2014-02-22 21:56:16.819 [New I/O worker #1] HTTP User-Agent: Showtime PS3 4.5.87.g59e59.dirty
DEBUG 2014-02-22 21:56:16.831 [New I/O worker #2] master is internal:net.pms.dlna.RealFile str Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv>D:\!torrent\!done\Mononoke hime - Princess Mononoke (1997)\Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv
DEBUG 2014-02-22 21:56:16.831 [New I/O worker #2] master is internal:net.pms.dlna.RealFile str Thor.The.Dark.World.2013.1080p.3D.HSBS.BluRay.x264.YIFY.mp4>D:\!torrent\!done\Thor The Dark World (2013) [3D] [HSBS]\Thor.The.Dark.World.2013.1080p.3D.HSBS.BluRay.x264.YIFY.mp4
DEBUG 2014-02-22 21:56:16.832 [New I/O worker #2] master is internal:net.pms.dlna.RealFile str The Hobbit An Unexpected Journey 3D 2012 Extended 1080p H-OU Multi BluRay x264 ac3 vice.mkv>D:\!torrent\!done\The Hobbit An Unexpected Journey 3D 2012 Extended 1080p H-OU Multi BluRay x264 ac3 vice\The Hobbit An Unexpected Journey 3D 2012 Extended 1080p H-OU Multi BluRay x264 ac3 vice.mkv
DEBUG 2014-02-22 21:56:16.832 [New I/O worker #2] master is internal:net.pms.dlna.RealFile str The Hobbit The Desolation of Smaug (2013) DVDSCR XviD-MAXSPEED www.torentz.3xforum.ro.avi>D:\!torrent\!done\The Hobbit The Desolation of Smaug (2013) DVDSCR XviD-MAXSPEED\The Hobbit The Desolation of Smaug (2013) DVDSCR XviD-MAXSPEED www.torentz.3xforum.ro.avi
DEBUG 2014-02-22 21:56:16.832 [New I/O worker #2] master is internal:net.pms.dlna.RealFile str sample.avi>D:\!torrent\!done\The Hobbit The Desolation of Smaug (2013) DVDSCR XviD-MAXSPEED\sample.avi
INFO  2014-02-22 21:56:16.834 [New I/O worker #2] Checking shared folder: D:\New Folder
DEBUG 2014-02-22 21:56:16.860 [New I/O worker #2] Starting transcode/remux of Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv with media info: container: null, bitrate: 0, size: 0, video codec: null, duration: null, width: 0, height: 0, frame rate: null, muxing mode: null, mime type: null
DEBUG 2014-02-22 21:56:16.863 [New I/O worker #1] Starting transcode/remux of Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv with media info: container: null, bitrate: 0, size: 0, video codec: null, duration: null, width: 0, height: 0, frame rate: null, muxing mode: null, mime type: null
DEBUG 2014-02-22 21:56:16.898 [New I/O worker #1] Creating pipe \\.\pipe\mencoder1393102576897
DEBUG 2014-02-22 21:56:16.898 [New I/O worker #2] Creating pipe \\.\pipe\mencoder1393102576897
DEBUG 2014-02-22 21:56:16.912 [Thread-12] Waiting for pipe connection \\.\pipe\mencoder1393102576897
DEBUG 2014-02-22 21:56:16.912 [mencoder.exe-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 35.0 "D:\New Folder\Mononoke hime - Princess Mononoke (1997)\Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv" -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=4 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=640:threads=4:keyint=5:vqscale=1:vqmin=2:vqmax=3:vrc_maxrate=499000:vrc_buf_size=1835 -nosub -noautosub -ofps 24000/1001 -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1393102576897
DEBUG 2014-02-22 21:56:16.913 [mencoder.exe-1] Reading pipe: \\.\pipe\mencoder1393102576897
DEBUG 2014-02-22 21:56:16.913 [mencoder.exe-1] Attaching thread: mencoder.exe-1
DEBUG 2014-02-22 21:56:16.915 [Thread-11] Waiting for pipe connection \\.\pipe\mencoder1393102576897
DEBUG 2014-02-22 21:56:16.916 [mencoder.exe-2] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "D:\New Folder\Mononoke hime - Princess Mononoke (1997)\Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv" -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=4 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=640:threads=4:keyint=5:vqscale=1:vqmin=2:vqmax=3:vrc_maxrate=499000:vrc_buf_size=1835 -nosub -noautosub -ofps 24000/1001 -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1393102576897
DEBUG 2014-02-22 21:56:16.917 [mencoder.exe-2] Reading pipe: \\.\pipe\mencoder1393102576897
DEBUG 2014-02-22 21:56:16.917 [mencoder.exe-2] Attaching thread: mencoder.exe-2
DEBUG 2014-02-22 21:56:16.924 [Thread-16] MEncoder SB55 (C) 2000-2014 MPlayer Team
DEBUG 2014-02-22 21:56:16.924 [Thread-16] Custom build by SubJunk, http://www.spirton.com
DEBUG 2014-02-22 21:56:16.926 [Thread-16] success: format: 0  data: 0x0 - 0x28a4cf9b
DEBUG 2014-02-22 21:56:16.926 [Thread-16] libavformat version 55.30.100 (internal)
DEBUG 2014-02-22 21:56:16.927 [Thread-16] libavformat file format detected.
DEBUG 2014-02-22 21:56:16.927 [Thread-20] MEncoder SB55 (C) 2000-2014 MPlayer Team
DEBUG 2014-02-22 21:56:16.927 [Thread-20] Custom build by SubJunk, http://www.spirton.com
DEBUG 2014-02-22 21:56:16.929 [Thread-20] success: format: 0  data: 0x0 - 0x28a4cf9b
DEBUG 2014-02-22 21:56:16.929 [Thread-20] libavformat version 55.30.100 (internal)
DEBUG 2014-02-22 21:56:16.930 [Thread-20] libavformat file format detected.
DEBUG 2014-02-22 21:56:16.933 [Thread-16] [lavf] stream 0: video (h264), -vid 0, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:16.933 [Thread-16] [lavf] stream 1: audio (aac), -aid 0, -alang jpn, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:16.933 [Thread-16] [lavf] stream 2: audio (aac), -aid 1, -alang eng, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:16.933 [Thread-16] [lavf] stream 3: subtitle (subrip), -sid 0, -slang eng, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:16.933 [Thread-16] VIDEO:  [H264]  1280x720  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2014-02-22 21:56:16.933 [Thread-16] [V] filefmt:44  fourcc:0x34363248  size:1280x720  fps:23.976  ftime:=0.0417
DEBUG 2014-02-22 21:56:16.933 [Thread-16] ==========================================================================
DEBUG 2014-02-22 21:56:16.933 [Thread-16] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2014-02-22 21:56:16.934 [Thread-16] libavcodec version 55.49.101 (internal)
DEBUG 2014-02-22 21:56:16.935 [Thread-16] AUDIO: 48000 Hz, 2 ch, floatle, 0.0 kbit/0.00% (ratio: 0->384000)
DEBUG 2014-02-22 21:56:16.935 [Thread-12] Result of \\.\pipe\mencoder1393102576897 : true
DEBUG 2014-02-22 21:56:16.935 [Thread-16] Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
DEBUG 2014-02-22 21:56:16.935 [Thread-16] ==========================================================================
DEBUG 2014-02-22 21:56:16.935 [Thread-16] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2014-02-22 21:56:16.936 [Thread-16] Opening video filter: [expand osd=1]
DEBUG 2014-02-22 21:56:16.936 [Thread-16] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
DEBUG 2014-02-22 21:56:16.936 [Thread-16] ==========================================================================
DEBUG 2014-02-22 21:56:16.936 [Thread-16] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2014-02-22 21:56:16.937 [Thread-20] [lavf] stream 0: video (h264), -vid 0, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:16.937 [Thread-20] [lavf] stream 1: audio (aac), -aid 0, -alang jpn, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:16.937 [Thread-20] [lavf] stream 2: audio (aac), -aid 1, -alang eng, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:16.937 [Thread-20] [lavf] stream 3: subtitle (subrip), -sid 0, -slang eng, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:16.937 [Thread-20] VIDEO:  [H264]  1280x720  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2014-02-22 21:56:16.937 [Thread-16] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2014-02-22 21:56:16.937 [Thread-20] [V] filefmt:44  fourcc:0x34363248  size:1280x720  fps:23.976  ftime:=0.0417
DEBUG 2014-02-22 21:56:16.937 [Thread-16] ==========================================================================
DEBUG 2014-02-22 21:56:16.937 [Thread-20] ==========================================================================
DEBUG 2014-02-22 21:56:16.937 [Thread-20] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2014-02-22 21:56:16.937 [Thread-15] [ac3 @ 010c0600]Channel layout not specified
DEBUG 2014-02-22 21:56:16.937 [Thread-15] [ac3 @ 010c0600]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2014-02-22 21:56:16.937 [Thread-20] libavcodec version 55.49.101 (internal)
DEBUG 2014-02-22 21:56:16.938 [Thread-20] AUDIO: 48000 Hz, 2 ch, floatle, 0.0 kbit/0.00% (ratio: 0->384000)
DEBUG 2014-02-22 21:56:16.938 [Thread-11] Result of \\.\pipe\mencoder1393102576897 : true
DEBUG 2014-02-22 21:56:16.938 [Thread-15] Limiting audio preload to 0.4s.
DEBUG 2014-02-22 21:56:16.938 [Thread-20] Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
DEBUG 2014-02-22 21:56:16.938 [Thread-15] Increasing audio density to 4.
DEBUG 2014-02-22 21:56:16.939 [Thread-20] ==========================================================================
DEBUG 2014-02-22 21:56:16.939 [Thread-20] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2014-02-22 21:56:16.939 [Thread-20] Opening video filter: [expand osd=1]
DEBUG 2014-02-22 21:56:16.939 [Thread-20] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
DEBUG 2014-02-22 21:56:16.939 [Thread-20] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2014-02-22 21:56:16.940 [Thread-20] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2014-02-22 21:56:16.940 [Thread-20] ==========================================================================
DEBUG 2014-02-22 21:56:16.940 [Thread-19] [ac3 @ 010c0600]Channel layout not specified
DEBUG 2014-02-22 21:56:16.940 [Thread-19] [ac3 @ 010c0600]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2014-02-22 21:56:16.940 [Thread-19] Limiting audio preload to 0.4s.
DEBUG 2014-02-22 21:56:16.940 [Thread-19] Increasing audio density to 4.
DEBUG 2014-02-22 21:56:16.950 [Thread-20] Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
DEBUG 2014-02-22 21:56:16.950 [Thread-20] videocodec: libavcodec (1280x720 fourcc=3267706d [mpg2])
DEBUG 2014-02-22 21:56:16.950 [Thread-20] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2014-02-22 21:56:16.954 [Thread-16] Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
DEBUG 2014-02-22 21:56:16.954 [Thread-16] videocodec: libavcodec (1280x720 fourcc=3267706d [mpg2])
DEBUG 2014-02-22 21:56:16.954 [Thread-16] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2014-02-22 21:56:16.974 [Thread-20] Writing header...
DEBUG 2014-02-22 21:56:16.974 [Thread-20] INITV: 0.200, 0.158, fps: 23.976
DEBUG 2014-02-22 21:56:16.978 [Thread-16] Writing header...
DEBUG 2014-02-22 21:56:16.978 [Thread-16] INITV: 0.200, 0.158, fps: 23.976
DEBUG 2014-02-22 21:56:19.683 [New I/O worker #3] Starting transcode/remux of Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv with media info: container: null, bitrate: 0, size: 0, video codec: null, duration: null, width: 0, height: 0, frame rate: null, muxing mode: null, mime type: null
DEBUG 2014-02-22 21:56:19.691 [New I/O worker #3] Creating pipe \\.\pipe\mencoder1393102579691
DEBUG 2014-02-22 21:56:19.704 [Thread-21] Waiting for pipe connection \\.\pipe\mencoder1393102579691
DEBUG 2014-02-22 21:56:19.704 [mencoder.exe-3] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "D:\New Folder\Mononoke hime - Princess Mononoke (1997)\Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv" -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=4 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=640:threads=4:keyint=5:vqscale=1:vqmin=2:vqmax=3:vrc_maxrate=499000:vrc_buf_size=1835 -nosub -noautosub -ofps 24000/1001 -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1393102579691
DEBUG 2014-02-22 21:56:19.705 [mencoder.exe-3] Reading pipe: \\.\pipe\mencoder1393102579691
DEBUG 2014-02-22 21:56:19.706 [mencoder.exe-3] Attaching thread: mencoder.exe-3
DEBUG 2014-02-22 21:56:19.767 [Thread-25] MEncoder SB55 (C) 2000-2014 MPlayer Team
DEBUG 2014-02-22 21:56:19.767 [Thread-25] Custom build by SubJunk, http://www.spirton.com
DEBUG 2014-02-22 21:56:19.769 [Thread-25] success: format: 0  data: 0x0 - 0x28a4cf9b
DEBUG 2014-02-22 21:56:19.770 [Thread-25] libavformat version 55.30.100 (internal)
DEBUG 2014-02-22 21:56:19.771 [Thread-25] libavformat file format detected.
INFO  2014-02-22 21:56:19.773 [New I/O worker #4] No IP filter specified, access granted to /10.1.1.2
DEBUG 2014-02-22 21:56:19.778 [Thread-25] [lavf] stream 0: video (h264), -vid 0, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:19.778 [Thread-25] [lavf] stream 1: audio (aac), -aid 0, -alang jpn, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:19.778 [Thread-25] [lavf] stream 2: audio (aac), -aid 1, -alang eng, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:19.778 [Thread-25] [lavf] stream 3: subtitle (subrip), -sid 0, -slang eng, Princess.Mononoke - YIFY
DEBUG 2014-02-22 21:56:19.778 [Thread-25] VIDEO:  [H264]  1280x720  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2014-02-22 21:56:19.778 [Thread-25] [V] filefmt:44  fourcc:0x34363248  size:1280x720  fps:23.976  ftime:=0.0417
DEBUG 2014-02-22 21:56:19.778 [Thread-25] ==========================================================================
DEBUG 2014-02-22 21:56:19.778 [Thread-25] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2014-02-22 21:56:19.778 [Thread-25] libavcodec version 55.49.101 (internal)
DEBUG 2014-02-22 21:56:19.779 [Thread-25] AUDIO: 48000 Hz, 2 ch, floatle, 0.0 kbit/0.00% (ratio: 0->384000)
DEBUG 2014-02-22 21:56:19.779 [Thread-21] Result of \\.\pipe\mencoder1393102579691 : true
DEBUG 2014-02-22 21:56:19.779 [Thread-25] Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
DEBUG 2014-02-22 21:56:19.780 [Thread-25] ==========================================================================
DEBUG 2014-02-22 21:56:19.780 [Thread-25] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2014-02-22 21:56:19.780 [Thread-25] Opening video filter: [expand osd=1]
DEBUG 2014-02-22 21:56:19.780 [Thread-25] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
DEBUG 2014-02-22 21:56:19.780 [Thread-25] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2014-02-22 21:56:19.781 [Thread-25] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2014-02-22 21:56:19.781 [Thread-25] ==========================================================================
DEBUG 2014-02-22 21:56:19.781 [Thread-24] [ac3 @ 010c0600]Channel layout not specified
DEBUG 2014-02-22 21:56:19.781 [Thread-24] [ac3 @ 010c0600]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2014-02-22 21:56:19.781 [Thread-24] Limiting audio preload to 0.4s.
DEBUG 2014-02-22 21:56:19.781 [Thread-24] Increasing audio density to 4.
DEBUG 2014-02-22 21:56:19.787 [New I/O worker #5] HTTP User-Agent: Linux/2.6.35 UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LGE_DLNA_SDK/1.6.0
INFO  2014-02-22 21:56:19.789 [pool-6-thread-2] Checking IP: 10.1.1.2 for LG Smart TV Upgrader
DEBUG 2014-02-22 21:56:19.821 [Thread-25] Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
DEBUG 2014-02-22 21:56:19.821 [Thread-25] videocodec: libavcodec (1280x720 fourcc=3267706d [mpg2])
DEBUG 2014-02-22 21:56:19.821 [Thread-25] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2014-02-22 21:56:19.888 [Thread-25] Writing header...
DEBUG 2014-02-22 21:56:19.888 [Thread-25] INITV: 0.200, 0.158, fps: 23.976
INFO  2014-02-22 21:56:21.499 [pool-6-thread-1] Renderer Showtime 4 found on this address: 10.1.1.8
DEBUG 2014-02-22 21:56:21.500 [pool-6-thread-1] Starting ping -n 3 -l 64000 10.1.1.8
DEBUG 2014-02-22 21:56:21.770 [Thread-28]
DEBUG 2014-02-22 21:56:21.770 [Thread-28] Pinging 10.1.1.8 with 64000 bytes of data:
DEBUG 2014-02-22 21:56:21.785 [Thread-28] Reply from 10.1.1.8: bytes=64000 time=8ms TTL=255
DEBUG 2014-02-22 21:56:22.784 [Thread-28] Reply from 10.1.1.8: bytes=64000 time=5ms TTL=255
DEBUG 2014-02-22 21:56:23.013 [New I/O worker #2] Setting InputStream new position to: 9 223 372 034 706 976 623
DEBUG 2014-02-22 21:56:23.017 [New I/O worker #1] Setting InputStream new position to: 9 223 372 034 706 792 159
INFO  2014-02-22 21:56:23.045 [StartPlaying Event] Started playing Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv on your Showtime 4
DEBUG 2014-02-22 21:56:23.046 [StartPlaying Event] The full filename of which is: D:\New Folder\Mononoke hime - Princess Mononoke (1997)\Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv and the address of the renderer is: 10.1.1.8
DEBUG 2014-02-22 21:56:23.508 [SpeedStats Failsafe] Stopping process: ping-4
INFO  2014-02-22 21:56:23.526 [pool-6-thread-1] Address /10.1.1.8 has an estimated network speed of: 78 Mb/s
INFO  2014-02-22 21:56:24.422 [pool-6-thread-2] Renderer LG Smart TV Upgrader found on this address: 10.1.1.2
DEBUG 2014-02-22 21:56:24.422 [pool-6-thread-2] Starting ping -n 3 -l 64000 10.1.1.2
DEBUG 2014-02-22 21:56:24.646 [Thread-31]
DEBUG 2014-02-22 21:56:24.646 [Thread-31] Pinging 10.1.1.2 with 64000 bytes of data:
DEBUG 2014-02-22 21:56:24.670 [Thread-31] Reply from 10.1.1.2: bytes=64000 time=12ms TTL=64
DEBUG 2014-02-22 21:56:25.710 [Thread-31] Reply from 10.1.1.2: bytes=64000 time=15ms TTL=64
INFO  2014-02-22 21:56:25.821 [StartPlaying Event] Started playing Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv on your Showtime 4
DEBUG 2014-02-22 21:56:25.829 [StartPlaying Event] The full filename of which is: D:\New Folder\Mononoke hime - Princess Mononoke (1997)\Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv and the address of the renderer is: 10.1.1.8
DEBUG 2014-02-22 21:56:26.310 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2014-02-22 21:56:26.435 [SpeedStats Failsafe] Stopping process: ping-5
INFO  2014-02-22 21:56:26.472 [pool-6-thread-2] Address /10.1.1.2 has an estimated network speed of: 37 Mb/s
DEBUG 2014-02-22 21:56:28.360 [Buffered IO End Checker] Stopping process: mencoder.exe-3
INFO  2014-02-22 21:56:29.911 [StopPlaying Event] Stopped playing Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv on your Showtime 4
DEBUG 2014-02-22 21:56:29.911 [StopPlaying Event] The full filename of which is: D:\New Folder\Mononoke hime - Princess Mononoke (1997)\Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv and the address of the renderer is: 10.1.1.8
DEBUG 2014-02-22 21:56:29.912 [StopPlaying Event] add MapFile [name=Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv, id=null, format=MKV, children=[]] to last played MapFile [name=Mononoke hime - Princess Mononoke (1997), id=0$2$1, format=null, children=[TranscodeVirtualFolder [id=1, name=#--TRANSCODE--#, full path=0$2$1$1, ext=null, discovered=false], MapFile [name=Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv, id=0$2$1$2, format=MKV, children=[]], MapFile [name=Mononoke.hime.[Princess.Mononoke].[DUAL.AUDIO]1997.HDTVRip.x264.YIFY.mkv, id=0$2$1$3, format=MKV, children=[]]]] RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=true]
INFO  2014-02-22 21:56:30.524 [New I/O worker #1] Buffer read ArrayIndexOutOfBoundsException error:
INFO  2014-02-22 21:56:30.524 [New I/O worker #1] readCount: "9223372034706792159"
INFO  2014-02-22 21:56:30.525 [New I/O worker #1] maxMemorySize: "209715200"
DEBUG 2014-02-22 21:56:46.797 [AWT-EventQueue-0] Checking dbgpack property in UMS.conf
DEBUG 2014-02-22 21:56:46.797 [AWT-EventQueue-0] adding C:\Program Files (x86)\Universal Media Server\renderers\Showtime4.conf
DEBUG 2014-02-22 21:56:46.798 [AWT-EventQueue-0] adding C:\Program Files (x86)\Universal Media Server\renderers\Showtime4.conf
DEBUG 2014-02-22 21:56:46.798 [AWT-EventQueue-0] adding C:\Program Files (x86)\Universal Media Server\renderers\LGST600.conf
DEBUG 2014-02-22 21:56:46.798 [AWT-EventQueue-0] adding C:\ProgramData\UMS\WEB.conf
DEBUG 2014-02-22 21:56:46.798 [AWT-EventQueue-0] adding C:\ProgramData\UMS\UMS.conf
DEBUG 2014-02-22 21:56:46.798 [AWT-EventQueue-0] adding C:\ProgramData\UMS\debug.log.prev
DEBUG 2014-02-22 21:56:47.457 [UPNP-AliveMessageSender] Sending ALIVE...
server: C2D E6750@2.66GHz 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
