Getting .m3u playlists to show on my receiver
My Pioneer VSX-1121-K has DLNA capabilities. Well, I want to be able to organize the music on my server, so I made a exported an itunes playlist in .m3u and after opening it in notepad and replacing "D:\Music\" with "..\Music\" to my surprise it actually worked. So I made multiple playlist and then discovered that only the first one worked. I figured it only supports one playlist, so I deleted them all and changed the main playlist that worked, to something else. I had the directories formatted the exact same way, but now the playlist isn't working. I'm totally stumped on this and have contact pioneer with no response. Anyone have any suggestions? Is there a way to get the "show iTunes Library" option to show your playlists also, even if their is my itunes library is so large when I check that option it freezes UMS. Thanks for any help
