Out of Memory Error.
God, I want to find an alternative to UMS.
Oh... "Increase Heap size" you say...
Already did that:
WHAT COULD UMS POSSIBLY BE DOING TO CONSUME 8 GIGABYTES of space????
I can't stream a single movie to completion before UMS craps out. It's been this way for several versions now and, as you can see from my post history, just another entry in a long line of this program just throws out exceptions.
ERROR 23:34:10.976 [GuiManager Memory Usage Updater] Database error on getting memory cache size
org.h2.jdbc.JdbcSQLNonTransientConnectionException: The database has been closed [90098-232]
at org.h2.message.DbException.getJdbcSQLException(DbException.java:690)
at org.h2.message.DbException.getJdbcSQLException(DbException.java:489)
at org.h2.message.DbException.get(DbException.java:212)
at org.h2.engine.SessionLocal.getTransaction(SessionLocal.java:1616)
at org.h2.engine.SessionLocal.startStatementWithinTransaction(SessionLocal.java:1637)
at org.h2.command.Command.executeQuery(Command.java:190)
at org.h2.jdbc.JdbcPreparedStatement.executeQuery(JdbcPreparedStatement.java:130)
at com.zaxxer.hikari.pool.ProxyPreparedStatement.executeQuery(ProxyPreparedStatement.java:52)
at com.zaxxer.hikari.pool.HikariProxyPreparedStatement.executeQuery(HikariProxyPreparedStatement.java)
at net.pms.database.DatabaseEmbedded.getCacheSize(DatabaseEmbedded.java:319)
at net.pms.database.MediaDatabase.getCacheSize(MediaDatabase.java:282)
at net.pms.gui.GuiManager.updateMemoryUsage(GuiManager.java:321)
at net.pms.gui.GuiManager.lambda$static$1(GuiManager.java:351)
Caused by: org.h2.mvstore.MVStoreException: java.lang.OutOfMemoryError: Java heap space [2.3.232/3]
at org.h2.mvstore.DataUtils.newMVStoreException(DataUtils.java:996)
at org.h2.mvstore.MVStore.tryExecuteUnderStoreLock(MVStore.java:941)
at org.h2.mvstore.RandomAccessStore.doHousekeeping(RandomAccessStore.java:729)
at org.h2.mvstore.FileStore.writeInBackground(FileStore.java:1841)
at org.h2.mvstore.FileStore$BackgroundWriterThread.run(FileStore.java:2256)
Caused by: java.lang.OutOfMemoryError: Java heap spaceAlready did that:
nas@ums:~$ ps -elf | grep java
0 S nas 196742 196741 0 80 0 - 4759322 futex_ 22:32 pts/2 02:27:41 jre17/bin/java [b]-Xmx8G[/b] -Xss2048k -Dfile.encoding=UTF-8 -Djava.net.preferIPv4Stack=true -Djna.nosys=true -classpath update.jar:ums.jar net.pms.PMS
0 S nas 214885 214867 0 80 0 - 1769 pipe_r 23:36 pts/3 00:00:00 grep --color=auto javaI can't stream a single movie to completion before UMS craps out. It's been this way for several versions now and, as you can see from my post history, just another entry in a long line of this program just throws out exceptions.
Re: Out of Memory Error.
Is this when playing with a LG TV?>
In the Linux version of UMS, the Java version used is the one supplied with UMS.
So changing the Java memory allocation in your system Java will have no effect.
You can either change the allocation in the supplied UMS Java or configure UMS to use your system Java.
This is done by editing the UMS.sh file in the UMS program folder like this.
To change the memory allocation in the UMS supplied version of Java, edit this:
To make UMS use your system Java:
Change this:
To this:
# Provide a means of setting max memory using an environment variable
if [ -z "$UMS_MAX_MEMORY" ]; then
UMS_MAX_MEMORY=1280M
fi
# Execute the JVM
exec "$JAVA" $JAVA_OPTS -Xmx$UMS_MAX_MEMORY -Xss2048k -Dfile.encoding=UTF-8 -Djava.net.preferIPv4Stack=true -Djna.nosys=true -classpath "$PMS_JARS" net.pms.PMS "$@"
Change this:
# Use our JVM if it exists
if [ -f jre17/bin/java ]; then
JAVA="jre17/bin/java"
fiCode: Select all
#if [ -f jre17/bin/java ]; then
# JAVA="jre17/bin/java"
#fiRe: Out of Memory Error.
@wiegleyj could you post your logs so I can see what could be causing this. One error message on its own is not enough. See the section in red above.
The previous problems you have asked about before you also did not supply logs so was unable to help and it was a long time till someone had the same issue for it to be fixed, like the illegal characters in filenames and OS language which were a unique Linux issues.
