I can not see MKV video files. Playback never starts on TV.
Alexmata
Post by Alexmata »
Hello, I do not speak English well. Forgive to me.
I have the latest version of the software UMS (3.4.2). My PC is an Intel quad-core 2.4 GHz with 4GB of DDR2 RAM and video card Geforce 9600 GT.
I have a Bravia HX TV series , and reproduce many mkv, but sometimes there are files that can not play . Leave a record of a movie in MKV format that I can see . And I put another log on mkv movie that I can not see :
Movie reproduced correctly:
General
Unique ID : 183581195296715502417597525787253274603 (0x8A1C73BE740221E9356D60DD8801F7EB)
Complete name : M:\Peliculas y Series\Series\Homeland\1ra Temporada\Homeland.S01E12.720p.HDTV.X264-DIMENSION.mkv
Format : Matroska
Format version : Version 2
File size : 1.90 GiB
Duration : 1h 24mn
Overall bit rate : 3 214 Kbps
Encoded date : UTC 2011-12-17 22:18:01
Writing application : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Apr 19 2010 11:58:49
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 24mn
Bit rate : 2 766 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.125
Stream size : 1.63 GiB (86%)
Writing library : x264 core 120 r2120 0c7dab9
Encoding settings : cabac=1 / ref=9 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : No
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 24mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 232 MiB (12%)
Default : Yes
Forced : No
Movie that can not be played:
General
Complete name : M:\Peliculas y Series\Series\Homeland\1ra Temporada\Homeland.S01E11.720p.HDTV.x264-IMMERSE.mkv
Format : Matroska
File size : 1.07 GiB
Duration : 54mn 30s
Overall bit rate : 2 823 Kbps
Writing application : x264.exe
Writing library : mkv2rls x264-tv version built on 2011. febr. 17
Video
Format : AVC
Format profile : High@L3.1
Format settings, ReFrames : 5 frames
Duration : 54mn 30s
Bit rate : 2 382 Kbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.108
Stream size : 929 MiB (84%)
Writing library : x264 core 119 r2106 07efeb4
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 54mn 30s
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 150 MiB (14%)
Language : English
Default : Yes
Forced : No
I hope I was clear. thank you very much
