Custom Avisynth script?
Is it possible to use the Avisynth/MEncoder transcoding to frameserve a custom Avisynth script? I have tried and failed many times. I simply want to be able to frameserve the following:
and that's it. How can this be done (if at all)? If UMS could frameserve custom avs scripts to DLNA clients (not just the Interframe and "2D to 3D" scripts that are built-in), it would be very powerful.
<movie>
left = selecteven()
right = selectodd()
stackhorizontal(left,right)
assumefps("ntsc_film")Re: Custom Avisynth script?
I don't think this is possible at the moment. but I don't know anything about Avisynth.
Is this for VR or 3D? if so another user contributed to add support for this and I think it used Avisynth.
I think it probably will do what you want but if not you could put in a request for this to either be built in or customisable script on Github.
You can read more about how the current 3D+VR is implemented here
