Adding Itunes library to UMS.
pinballreed
I have my itunes library on a network share and am using UMS on the same computer that I am also running iTunes windows. When I attempt to add the Itunes library, it does not allow specification of a file, just a folder.
This is the error I am seeing in the log file.
16:19:37 ERROR Something went wrong with the iTunes Library scan:
xmlwise.XmlParseException: org.xml.sax.SAXParseException; systemId: file:/M:/itunes/; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
....snip....
Caused by: org.xml.sax.SAXParseException: Content is not allowed in prolog.
at java.xml/com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at java.xml/javax.xml.parsers.DocumentBuilder.parse(Unknown Source)
at xmlwise.Xmlwise.loadDocument(Xmlwise.java:50)
... 44 common frames omitted
16:23:30 INFO [Fatal Error] :1:1: Content is not allowed in prolog.
16:23:30 ERROR Something went wrong with the iTunes Library scan:
....snip....
The file: iTunes Library.xml exists in the folder I specified.
Thoughts?
....snip....
....snip....
Thoughts?
Re: Adding Itunes library to UMS.
I have seen the message "Content is not allowed in prolog" but never found the exact cause.
It would be helpful to see your full logs to know what is happening. See the link in my sig.
