Your browse data was not received from the server.
BrittaS090384
my problem is that UMS is running, but none of my shared folders are visible. I'm getting the error message mentioned in the subject line, and I can't figure it out since everything works perfectly fine on another PC in my household. Could someone please help me?
Thank you so much in advance.
Re: Your browse data was not received from the server.
Look like the database upgrade failed after updating UMS
There was some other exception errors but the logs were not in trace mode so could not see the the full picture, but that database error would cause these.
Try deleting or renaming C:\ProgramData\UMS\database\medias.mv.db when UMS is not running so a new database will be built when it is next run.
If you are still having problems try doing some more logs making sure it is in TRACE mode. If for some reason it is not switching modes when making the logs you can force it by setting in C:\ProgramData\UMS\UMS.conf
INFO 2025-11-02 00:59:01.664 [main] Upgrading database "medias" table "VIDEO_METADATA" from version 4 to 9
ERROR 2025-11-02 00:59:01.779 [main] Error checking tables: Feld "ISSAMPLE" nicht gefunden
Column "ISSAMPLE" not found; SQL statement:
CREATE INDEX IF NOT EXISTS VIDEO_METADATA_BASIC_COLUMNS_IDX ON VIDEO_METADATA(IMDBID, MEDIA_YEAR, TITLE, TVSERIESID, EXTRAINFORMATION, ISTVEPISODE, TVSEASON, TVEPISODENUMBER, ISSAMPLE) [42122-240]Try deleting or renaming C:\ProgramData\UMS\database\medias.mv.db when UMS is not running so a new database will be built when it is next run.
log_level =TRACELogs are important for us to help, Please follow This Link before asking for support. Just a forum cleaner, Will help if I can but no expert.
