Import config file
Import config file
How do I import a config file for my device (Cambridge Audio 752BD) into UMS using OS X ?
Under Windows I understand you copy the config file to the renderers directory in c:\program files\universal media server\ and then restart ums but on my OS X installation such a directory doesn't exist ?
- Optimus_prime
Re: Import config file
Could you see if this helps viewtopic.php?f=11&t=1684
If not i will give you better instructions
