[Solved] DVD ISO playback appears broken
I have been trying to rip some DVDs and play them back via UMS, which should be possible according to the documentation I can find. I have tested the rips in VLC and by dragging them on to the mplayer.exe in the UMS /bin folder and they play fine (no CSS).
If I view them on either my LG CX TV or the built-in web player nothing happens. The web player shows a blank screen (see screenshot) and the TV does not open anything.
Advice?
Running UMS-Windows-15.8.0-x86_64, fresh install including config. Logs attached.
Advice?
- ums_dbg_2026-08-18-03-49.zip
- (112.15 KiB) Downloaded 239 times
Re: DVD ISO playback appears broken
I could not see much about any video files to play but did see references to that ISO
I downloaded an ISO to test myself and I have the same result, the ISO does appear as a folder both in the browser and on my TV but is empty.
I don't see anything in the settings that could cause it so I'll report it as an issue on GitHub for the devs to investigate.
Hi Cathexis, this is fixed now in our upcoming release, would you like me to message you a download link?
