renderers
nmharleyrider1
renderers
Post by nmharleyrider1 »
I have been trying to get the renderers so show up for many months now after over 10 years of using this software. I do not know what has happened but I have not had this problem for a long time.
ums_dbg_2026-10-08-11-19.zip
(114.09 KiB) Downloaded 13 times
Re: renderers
I do see errors about the network interface being null
DEBUG 2026-10-08 11:17:04.370 [main] net.pms.network.configuration.NetworkConfiguration Using forced address: 192.0.0.223
ERROR 2026-10-08 11:17:04.376 [main] net.pms.PMS A serious error occurred during Universal Media Server initialization: Cannot invoke "java.net.NetworkInterface.isUp()" because "tmpNetworkInterface" is null
DEBUG 2026-10-08 11:17:04.376 [main] net.pms.PMS
java.lang.NullPointerException: Cannot invoke "java.net.NetworkInterface.isUp()" because "tmpNetworkInterface" is null
	at net.pms.network.configuration.NetworkConfiguration.getNetworkInterfaceAssociationFromConfig(NetworkConfiguration.java:682)
	at net.pms.network.mediaserver.MediaServer.init(MediaServer.java:58)
	at net.pms.network.mediaserver.MediaServer.start(MediaServer.java:81)
	at net.pms.PMS.init(PMS.java:437)
	at net.pms.PMS.createInstance(PMS.java:1011)
	at net.pms.PMS.main(PMS.java:962)
In your UMS.conf there is no setting for network_interface so UMS should auto detect but I think the problem is you have set a forced IP address that may not be available on any network interface so is returning the null result.
# Force IP of the Media Server
# A network interface can have multiple IP addresses associated with it.
# This sets which one should be used.
# Default: "", which means UMS will automatically select an IP address.
hostname = 192.0.0.223
This does not look right for a local network IP as it usually is 192.168.x.x but I know little about networking and how IPs are assigned.
There is an available interface on 10.0.0.223 and the IP you used was maybe a typo. I know 10.0.0.x is another way of having local IPs.
checking wlan2(5), display name: Intel(R) Wi-Fi 6E AX211 160MHz
available addresses for wlan2 is: [/10.0.0.223]
Try removing the forced IP so UMS can automatically detect it.
