Which version of Java do you use?
cyberbooster
Hi all,
just to know... Which version of java do you use? Could be helpful to know, in order to focus development effort to the most used
I use Java 1.7.0_45, but I could upgrade to any one easily (UMS the only java software I use...).
If you don't know how to check, openup a terminal and write:
java -version
- Optimus_prime
Re: Which version of Java do you use?
So can i check all three, i'm always swapping between all three
As of now I'm using java 8 with UMS java 7 version for MAC.
Some glitches on loading times , but further on it runs well.
- Optimus_prime
Snakebyte, have you given the Java 8 version a go?
Optimus,
Had not checked for it yet, but downloaded immediately and will give it a try.
I keep you posted on my findings.
Thanks and greets
Thanks and greets
