Samsung D6500 HDTV ( embedded subtitles problem )
I'm trying to watch anime with embedded subtitles with this TV. But there is a problem.
For embedded subtitles to work as I understand I should put "MediInfo=true" in renderer configuration..
But when I put this line my TV doesn't like transcoded files at all.. Every codec ( Mencoder, ffmpeg, avisynth etc ) gives video codec error.
Is there a solution for this TV to show embedded ASS subtitles without MediaInfo parameter?
Re: Samsung D6500 HDTV ( embedded subtitles problem )
Ok,
I found the solution within this group, someone posted configuration for 40D6500. And while I had my suspicions, files played with subtitles no problem.. One thing though. First files I tried before changing configuration cannot be parsed. I checked other episodes and there is no problem. I'll try again after deleting resume data for those files. Maybe the error was there...
BTW, is there any way to correctly calculate movie's length so we can seek? It is tiring to wait for the intros, etc..
