Doubt and request for help.
First of all, let me congratulate you for this exelent media streamer, for me is the best one avalible. My only regreats is that i didn't know about it earlier, it would have saved me alot of trouble with the 1080p .mkv's and another media server...
But anyway, i don't now if this is the right place to post this message, but i need help, maybe i'm doing someting wrong...
It has to do with MKV 3d movies format and the damn subtitles for it.
From a normal .srt file i create a 3d subtitle and then mux it with the .mp4, creating a .mkv file with the embeded subtitles, the "problem" star at this point...
In my laptop the file opens just right, with the subtitles divided in the two sides of the movie, when i stream it to the PS3 using the old streamer (PS3MS) the subtitles also appear as they should, but as always it starts lagging 2 minutes after the movie started (even with an wirered network).
With UMS i don't have the lag problem (even with a wireless network), but... the subtitles don't apear!
Am I doing something wrong? Is there an unchecked check box on UMS that comes checked by default in PS3MS, that I'm missing?
Sorry, i'm a noob on this things, but i'm a fast learner. (And i'm also portuguese, so sorry about any spelling errors
Thank you.
Thank you.
Re: Doubt and request for help.
Welcome to the forum BolaSnoW
You can use the TRANSCODE folder to select subtitles
