Problem for subtitle
fackir
Post by fackir »
Hi guys,
I have problems with subtitles. This is a big problem for the non English speakers. Regrets for some reason the subtitles although they are of the same extension a movie title, do not leave work. However, if you reinstall the server, things happen. This occurs only occasionally and not directly dependent on the shape of the film. Subtitles are always in Unicode format *. sub or *. srt. My TV is Samsung 40F5500 and maintains quite formats that are not described in allshare config file.
Can you suggest a solution to my leaving the subtitles every time? Sory for my very bad ENG. My PC system: Windows 7x64, JAVA x86 x64.
Samsung 5 seria video suport.JPG (112.86 KiB) Viewed 4383 times
