[Solved] Cant stream any MP4 files using UMS 4.0.2
Hi, After upgrading to v4.0.0 (and now tried v4.0.1) I find that none of my mp4 videos will stream to my Bravia W series TV.
If I reinstall version 3.6.4 all the MP4 files stream correctly.
Is this a bug in v4? or is there a setting that I'm missing?
Cant stream any MP4 files using UMS 4.0.0
I was going to make a thread about this, because I am having the same issue.
But I can confirm this happens in my Panasonic TC-P42XT50X too.
when 3.6.0 was released I tested and had to delete this line from Panasonic.conf "MimeTypesChanges=audio/wav=audio/L16|video/mp4=video/mpeg|video/mkv=video/mpeg" to make mp4 stream correctly, because it was displaying every mp4 as "MPEG2-PS", nor working as expected while other formats worked fine, like mkv and flv etc.
everything was again fine as always.
but with UMS4, this problem doesn't seem to get fixed, no matter how many lines I delete or change from Panasonic.conf, mediainfo=off and StreamExtensions=mp4.... deactivate every transcode engine in UMS, using the old UMS.conf or new, using the UMS 4 java 8... etc, it always displays mp4 as MPEG2-PS and it won't even play those files in my tv in most cases.
of course when I drag and drop the ums.jar from 3.6.4 (so I can go back to that version), everything works perfect in a second, and mp4 start working again, but once I put the ums.jar from UMS4 beta or final, and open UMS, the mpeg2-ps troll label appear again in my tv, not letting me watch mp4s again.
at least 3.6.4 seems to work always good, but I hope there is a fix to this mp4 issue.
Re: Cant stream any MP4 files using UMS 4.0.0
MP4s unplayable here as well through my ps3
Re: Cant stream any MP4 files using UMS 4.0.x
Please find attached debug log as requested
- ums_dbg.zip for UMS 4.0.2
- (22.55 KiB) Downloaded 693 times
For the braviaw user/s try my suggestion here
viewtopic.php?f=9&t=2075#p11498
For others i suggest you start you own thread relevant to your own problem devices
Paradox, thanks for your suggestion, however this issue was caused by a bug in UMS.
SubJunk has found and fixed the issue in 4.0.3
Theres a version 4.0.3 already? I was not aware of that.
There have been some 4.0.3 previews posted as I tracked down the bug and now it's fixed in this version: http://www.spirton.com/uploads/UMS/UMS-3602b2b.exe
CoolSubJunk wrote:There have been some 4.0.3 previews posted as I tracked down the bug and now it's fixed in this version: http://www.spirton.com/uploads/UMS/UMS-3602b2b.exe
I'm also seeing the same behaviour where the PS3 is not served the mp4 file but a transcoded/remuxed one without need, and looking at the debug files I think it's related to the parsing of the file metadata, specifically the container part. Ie in a sample file that plays unchanged on UMS3.6 series, when playing on latest 4.0.3 build it behaves as if playing a mov file:
And when analysing what ffmpeg is detecting:
When analyzed by latest Mediainfo it matches what ffmpeg is detecting (MPEG4 ISOM container instead of MOV), but somehow goes interpreted wrong on the supported format decision later:
I hope it helps, Wolf
DEBUG 2014-08-10 14:30:26.146 [New I/O worker #2] Starting transcode/remux of MythBusters.S14E05.Laws.of.Attraction.HDTV.x264-FUM.mp4 with media info: container: mov, bitrate: 972800, size: 292594748, video codec: h264 (High) (avc1 / 0x31637661), duration: 00:41:01.95, width: 720, height: 404, frame rate: 29.97, muxing mode: null, mime type: video/mp4
Audio track id: 0, lang: und, flavor: null, audio codec: aac (mp4a / 0x6134706D), sample frequency:48000, number of channels: 2, bits per sample: 16, artist: , album: , song name: , year: 0, track: 0Code: Select all
DEBUG 2014-08-10 14:30:26.287 [New I/O worker #2] Starting D:\Program Files\Universal Media Server test\win32\ffmpeg.exe -i E:\zInetTransfer\!(0TV) Various\MythBusters.S14E05.Laws.of.Attraction.HDTV.x264-FUM.mp4 -vframes 1 -c:v copy -f h264 -bsf h264_mp4toannexb -an -y pipe:
DEBUG 2014-08-10 14:30:27.568 [New I/O worker #2] Attaching thread: ffmpeg.exe-1
DEBUG 2014-08-10 14:30:28.240 [ffmpeg.exe-1-2] ffmpeg version N-64711-gfa6716c Copyright (c) 2000-2014 the FFmpeg developers
DEBUG 2014-08-10 14:30:28.240 [ffmpeg.exe-1-2] built on Jul 16 2014 22:02:05 with gcc 4.8.3 (GCC)
DEBUG 2014-08-10 14:30:28.240 [ffmpeg.exe-1-2] configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib
DEBUG 2014-08-10 14:30:28.240 [ffmpeg.exe-1-2] libavutil 52. 92.100 / 52. 92.100
DEBUG 2014-08-10 14:30:28.240 [ffmpeg.exe-1-2] libavcodec 55. 69.100 / 55. 69.100
DEBUG 2014-08-10 14:30:28.240 [ffmpeg.exe-1-2] libavformat 55. 48.101 / 55. 48.101
DEBUG 2014-08-10 14:30:28.240 [ffmpeg.exe-1-2] libavdevice 55. 13.102 / 55. 13.102
DEBUG 2014-08-10 14:30:28.255 [ffmpeg.exe-1-2] libavfilter 4. 11.100 / 4. 11.100
DEBUG 2014-08-10 14:30:28.255 [ffmpeg.exe-1-2] libswscale 2. 6.100 / 2. 6.100
DEBUG 2014-08-10 14:30:28.255 [ffmpeg.exe-1-2] libswresample 0. 19.100 / 0. 19.100
DEBUG 2014-08-10 14:30:28.255 [ffmpeg.exe-1-2] libpostproc 52. 3.100 / 52. 3.100
DEBUG 2014-08-10 14:30:28.365 [ffmpeg.exe-1-2] Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\zInetTransfer\!(0TV) Various\MythBusters.S14E05.Laws.of.Attraction.HDTV.x264-FUM.mp4':
DEBUG 2014-08-10 14:30:28.365 [ffmpeg.exe-1-2] Metadata:
DEBUG 2014-08-10 14:30:28.365 [ffmpeg.exe-1-2] major_brand : isom
DEBUG 2014-08-10 14:30:28.365 [ffmpeg.exe-1-2] minor_version : 1
DEBUG 2014-08-10 14:30:28.365 [ffmpeg.exe-1-2] compatible_brands: isomavc1
DEBUG 2014-08-10 14:30:28.365 [ffmpeg.exe-1-2] creation_time : 2014-08-08 03:24:42
DEBUG 2014-08-10 14:30:28.365 [ffmpeg.exe-1-2] Duration: 00:41:01.95, start: 0.000000, bitrate: 950 kb/s
DEBUG 2014-08-10 14:30:28.380 [ffmpeg.exe-1-2] Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 720x404, 826 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc (default)
DEBUG 2014-08-10 14:30:28.380 [ffmpeg.exe-1-2] Metadata:
DEBUG 2014-08-10 14:30:28.380 [ffmpeg.exe-1-2] creation_time : 2014-08-08 03:24:42
DEBUG 2014-08-10 14:30:28.380 [ffmpeg.exe-1-2] Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 119 kb/s (default)
DEBUG 2014-08-10 14:30:28.380 [ffmpeg.exe-1-2] creation_time : 2014-08-08 03:07:30
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] Output #0, h264, to 'pipe:':
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] Metadata:
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] major_brand : isom
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] minor_version : 1
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] compatible_brands: isomavc1
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] encoder : Lavf55.48.101
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] Stream #0:0(und): Video: h264 (avc1 / 0x31637661), yuv420p, 720x404, q=2-31, 826 kb/s, 29.97 fps, 29.97 tbn, 29.97 tbc (default)
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] creation_time : 2014-08-08 03:24:42
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] Stream mapping:
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] Stream #0:0 -> #0:0 (copy)
DEBUG 2014-08-10 14:30:28.396 [ffmpeg.exe-1-2] Press [q] to stop, [?] for help
DEBUG 2014-08-10 14:30:28.412 [ffmpeg.exe-1-2] frame= 1 fps=0.0 q=-1.0 Lsize= 1kB time=00:00:00.03 bitrate= 217.2kbits/s
DEBUG 2014-08-10 14:30:28.412 [ffmpeg.exe-1-2] video:1kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%
General
Complete name : E:\zInetTransfer\!(0TV) Various\MythBusters.S14E05.Laws.of.Attraction.HDTV.x264-FUM.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 279 MiB
Duration : 41mn 1s
Overall bit rate mode : Variable
Overall bit rate : 951 Kbps
Encoded date : UTC 2014-08-08 03:24:42
Tagged date : UTC 2014-08-08 03:24:42
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 41mn 1s
Bit rate : 826 Kbps
Maximum bit rate : 4 056 Kbps
Width : 720 pixels
Height : 404 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.095
Stream size : 242 MiB (87%)
Writing library : x264 core 142 r2453 ea0ca51
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=17500 / vbv_bufsize=17500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2014-08-08 03:26:02
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 41mn 1s
Bit rate mode : Variable
Bit rate : 120 Kbps
Maximum bit rate : 153 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 35.2 MiB (13%)
Encoded date : UTC 2014-08-08 03:07:30
