Several problems with latest version.
Arkadietz
Post by Arkadietz »
TV Model: SONY 50W815W
Wired Connection 100 Mb/s
When i check "keep DTS Tracks" the picture is going blurred.
Some .mp4 files won't start.
Some .mkv files won't start. (it gives me current bitrate 120/140 which is not possible)
Some external subs won't loaded.
The size of subs are not equal with different films.
Paradox
Re: Several problems with latest version.
Post by Paradox »
DTS is not compatible on most bravias
.MP4 and .MKV files will require transcoding (turn off the mux with tsmuxer option)
Subs have been an issue for numerous releases with sonys
Sub siz will differ if using .idx/.sub sub types
Hopefully the MP4 and external subtitle issues are fixed in this version: http://www.spirton.com/uploads/UMS/UMS-cc9f131.exe
Arkadietz
Post by Arkadietz »
For now what i've been test it all works fine. The problem now is with subs's bulk/mass. With some films i don't know why but subs seems are like crushed ( smashed ) and padded. With others are just fine. And this is really annoying.
Does this fix the subtitle stretching? http://www.spirton.com/uploads/UMS/UMS-21d821a.exe
Arkadietz
Post by Arkadietz »
SubJunk wrote:Does this fix the subtitle stretching? http://www.spirton.com/uploads/UMS/UMS-21d821a.exe
Nah, still the same. I have uploaded two snapshots u can see the differences. In the first picture all is looking fine ( it's 720.mkv TV Show ( Suits) ) the other pic is how i said like smashed or whatever.
Fine:
Bad:
Here are the snapshots of my UMS settings. If i need to change something tell me what and where.
