Cant play any files
gyrfalcon
Cant play any files
Post by gyrfalcon »
If I try to upload the file it logs me out..But here's the post with out the zip file, see if this works:
I have a denon receiver (aka streamium) and a sony blue ray play accessing UMS-4.0.3 on MacOS X 10.9.4. Neither can play any music file. The denon receiver navigates the folders and shows the music files, but says "Connection Lost" when I select any file. The sony player navigates to the folders but says no playable files instead of showing any files.
the debug zip has a denonavre400.conf, its just a renamed streamium.conf with a new icon to make things pretty.
Since I can't upload the .zip file w/out getting logged out, any other way to provide that info?
Ideas?
Optimus_prime
Re: Cant play any files
Post by Optimus_prime »
Post the Debug Text within a "" box, using the code button above the post box and i'll take a look at it
gyrfalcon
Post by gyrfalcon »
Ok, now its logging me out when I try to
it....file size problem?
gyrfalcon
Post by gyrfalcon »
tar.gz of denon and sony trace logs, see if this is small enough:
ah, there we go
debug.tar.gz
(8.93 KiB) Downloaded 431 times
