tsMuxeR-new.exe has a return code of -2!
zer0900
Post by zer0900 »
Running UMS 4.0.3.Trying to stream a 720p movie on a wired network, this is the only file it seems to have an issue with, but said file plays fine on vlc on pc.
I googled around but could only get results for PMS on this error, never the less I tried the fixes, cleared cache, made sure there was enough cpu power, checked settings were indeed set for wired network, etc..
Any ideas?
edit: I am streaming to PS3, the ps3 itself gives this error on screen
This content cannot be played.
(800288E1)
UMS log file:
DEBUG 2014-08-22 08:32:09.826 [StartPlaying Event] The full filename of which is: D:\Movies\a\Ta.mkv and the address of the renderer is: 192.168.1.31
DEBUG 2014-08-22 08:32:10.610 [mencoder.exe-2] Attaching thread: mencoder.exe-2
DEBUG 2014-08-22 08:32:10.801 [mencoder.exe-3] Attaching thread: mencoder.exe-3
DEBUG 2014-08-22 08:32:11.102 [Thread-21] Result of \\.\pipe\1408692729017ffmpegaudio01 : true
DEBUG 2014-08-22 08:32:11.123 [Thread-17] Result of \\.\pipe\1408692728997ffmpegvideo : true
DEBUG 2014-08-22 08:32:11.192 [Thread-29] Decoding H264 stream (track 1): Profile: High@4.1  Resolution: 1280:720p  Frame rate: 23.976
DEBUG 2014-08-22 08:32:11.192 [Thread-29] Change H264 level from 4.1 to 4.1
DEBUG 2014-08-22 08:32:11.255 [Thread-24] Result of \\.\pipe\1408692729023tsmuxerout.ts : true
DEBUG 2014-08-22 08:32:11.257 [Thread-29] 100.0% complete
DEBUG 2014-08-22 08:32:11.257 [Thread-29] H264 bitstream changed: insert nal unit delimiters
DEBUG 2014-08-22 08:32:11.257 [Thread-29] Decoding AC3 stream (track 2): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 5.1
DEBUG 2014-08-22 08:32:11.520 [ffmpeg.exe-1-Cleanup] Stopping process: ffmpeg.exe-1
DEBUG 2014-08-22 08:32:11.535 [Thread-29] 100.0% complete
DEBUG 2014-08-22 08:32:11.589 [tsMuxeR-new.exe-4-2] Not enought buffer for parse video stream. Current frame num 21
DEBUG 2014-08-22 08:32:11.598 [Thread-18] Disconnected pipe: \\.\pipe\1408692728997videoout
INFO  2014-08-22 08:32:11.599 [tsMuxeR-new.exe-4] Process C:\Program Files (x86)\Universal Media Server\win32\tsMuxeR-new.exe has a return code of -2! Maybe an error occurred... check the log file
DEBUG 2014-08-22 08:32:11.602 [tsMuxeR-new.exe-4] Stopping process: mencoder.exe-2
DEBUG 2014-08-22 08:32:11.602 [Thread-17] Error: null
DEBUG 2014-08-22 08:32:11.602 [tsMuxeR-new.exe-4] Stopping process: mencoder.exe-3
DEBUG 2014-08-22 08:32:11.603 [Thread-22] Error: null
DEBUG 2014-08-22 08:32:11.606 [Thread-22] Disconnected pipe: \\.\pipe\1408692729017audioout
DEBUG 2014-08-22 08:32:11.607 [Thread-21] Error: null
DEBUG 2014-08-22 08:32:11.610 [Thread-20] Error :Read end dead
DEBUG 2014-08-22 08:32:11.610 [Thread-16] Error :null
DEBUG 2014-08-22 08:32:12.327 [tsMuxeR-new.exe-4-Cleanup] Stopping process: tsMuxeR-new.exe-4
INFO  2014-08-22 08:32:16.023 [StopPlaying Event] Stopped playing Ta.mkv on your PlayStation 3
DEBUG 2014-08-22 08:32:16.024 [StopPlaying Event] The full filename of which is: D:\Movies\Ta\Ta.mkv and the address of the renderer is: 192.168.1.31
INFO  2014-08-22 08:32:44.237 [AWT-EventQueue-0] Changed debug level to TRACE
DEBUG 2014-08-22 08:32:45.957 [AWT-EventQueue-0] Checking dbgpack property in UMS.conf
DEBUG 2014-08-22 08:32:45.957 [AWT-EventQueue-0] adding C:\Program Files (x86)\Universal Media Server\renderers\PS3.conf
DEBUG 2014-08-22 08:32:45.958 [AWT-EventQueue-0] adding C:\ProgramData\UMS\WEB.conf
DEBUG 2014-08-22 08:32:45.958 [AWT-EventQueue-0] adding C:\ProgramData\UMS\UMS.conf
DEBUG 2014-08-22 08:32:45.958 [AWT-EventQueue-0] adding C:\ProgramData\UMS\debug.log.prev
TRACE 2014-08-22 08:32:50.536 [UPNPHelper] Receiving a NOTIFY from [192.168.1.10:1900]
TRACE 2014-08-22 08:32:50.537 [UPNPHelper] Receiving a NOTIFY from [192.168.1.10:1900]
TRACE 2014-08-22 08:32:50.549 [UPNPHelper] Receiving a NOTIFY from [192.168.1.10:1900]
TRACE 2014-08-22 08:32:50.568 [UPNPHelper] Receiving a NOTIFY from [192.168.1.10:1900]
DEBUG 2014-08-22 08:32:52.222 [AWT-EventQueue-0] packing C:\Program Files (x86)\Universal Media Server\renderers\PS3.conf
DEBUG 2014-08-22 08:32:52.225 [AWT-EventQueue-0] packing C:\ProgramData\UMS\WEB.conf
DEBUG 2014-08-22 08:32:52.225 [AWT-EventQueue-0] packing C:\ProgramData\UMS\UMS.conf
DEBUG 2014-08-22 08:32:52.228 [AWT-EventQueue-0] packing C:\ProgramData\UMS\debug.log
