UMS 4.0.3 inconsistent behavior
justforgetme
I was using the 2.6 version of UMS for a long time on my PS3 and LG 6200. Installed UMS 4.0.3 from the aur https://aur.archlinux.org/packages/ums/ and now only my Smart TV does play videos. Any attempt to play a video File on the PS3 ends in following error report:
Any ideas?
Edit: All files are Pristine except the ~/.config/UMS/UMS.conf Which has my shares in it and was written by UMS itself.
ERROR 2014-08-27 07:52:53.076 [Hanging External Process Stopper] External input stream instance is null... stopping process
ERROR 2014-08-27 07:52:53.076 [New I/O worker #9] There is no inputstream to return for Elementary S01E10 The Leviathan
WARN 2014-08-27 07:53:03.078 [Process Destroyer] Sending kill -14 to the Unix process: 18609
WARN 2014-08-27 07:53:03.079 [Process Destroyer] Sending kill -14 to the Unix process: 18624
ERROR 2014-08-27 07:53:03.708 [Hanging External Process Stopper] External input stream instance is null... stopping process
ERROR 2014-08-27 07:53:03.708 [New I/O worker #10] There is no inputstream to return for Elementary S01E10 The Leviathan
- (107.26 KiB) Downloaded 299 times
Re: UMS 4.0.3 inconsistent behavior
Does it still happen if you let UMS generate a new UMS.conf file?
