Yamaha NP-S2000
Yamaha NP-S2000
Has anyone tried to connect UMS to Yamaha NP-S2000 network media renderer? It is not found by UMS(nor it can detect ums server running) initially and after I tried the described steps to create custom renderer.conf(copied some Yamaha audio receiver config) I'm only able to see the following TRACE messages from yamaha(it has fixed IP = 192.168.5.13) in debug.log:
No User-Agent or other info from the client is seen. Other DLNA linux servers, such as minidlna and XBMC work OK with it. What I'm doing wrong?
TRACE 2014-08-30 15:08:39.267 [UPNPHelper] Receiving a M-SEARCH from [192.168.5.13:5732]
TRACE 2014-08-30 15:08:39.268 [UPNPHelper] Sending this reply [192.168.5.13:5732]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Sat, 30 Aug 2014 11:08:39 GMT<CRLF>LOCATION: http://10.98.1.54:5001/description/fetch<CRLF>SERVER: Linux-amd64-3.14.17, UPnP/1.0, UMS/4.0.3<CRLF>ST: urn:schemas-upnp-org:device:MediaServer:1<CRLF>EXT: <CRLF>USN: uuid:ecccea7b-5542-475d-8cdc-3a4dfdf397c5::urn:schemas-upnp-org:device:MediaServer:1<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2014-08-30 15:09:37.594 [UPNPHelper] Receiving a NOTIFY from [192.168.5.13:5732]
TRACE 2014-08-30 15:09:37.595 [UPNPHelper] Receiving a NOTIFY from [192.168.5.13:5732]
Re: Yamaha NP-S2000
Can you please attach the full logs for us using UMS 5.0.0-a1?
