Mencoder stops working
demetrish3
ok this is too complicated.
since yestrday everything was working fine on the PS3media server, since i tried to fix the subtitles for a 3D movie with the "3D Subtitler" which changes the file from.srt to .sub and .idx
it never worked anyway, as i figured out that the VOBSUB is not supprorted on PMS. or the .sub subtitles. (in the transcodes there are many options to select the movie and when i select anything which says VOBSUB it doesn't even start),
and since i tried all this i ended with a permament problem which i never had.
till yesterday i could play any file in the transcoded Movie.
Now i cant !
when i select the very first which is (Avisynth/Enconder) it always appears the message "this data type is not supported (800288E1).
and then a pop-up window appears in my pc which says "Mencoder stopped working",
then i try to play the movie with the other transcoder (Mencoder) and it works fine.
so what is the problem?
Mencoder? Avisynth? Ffmpeg? Vobsub?
what does 800288E1 mean?
i've unistalled and then installed everything but the problem remains. also i did a system restore, again the problem remains.
and this started since i tried to play 3D movie with the converted subtitles.
Now i cant !
