Problem with mplayer prog/engines
gambit
Post by gambit »
when i open the program i see that i get some errors in the log and the mplayer engines do not load, i am wondering if this i have windows home server 2011 and when installing maybe didnt install the mplayer correctly
(14.17 KiB) Downloaded 841 times
gambit
Re: Problem with mplayer prog/engines
Post by gambit »
anyone?
Does "C:\Program Files (x86)\Universal Media Server\win32\mplayer.exe" exist?
gambit
Post by gambit »
dont really know, have to check. I know before 1.4 it would work but than i installed 1.4 and been having this problem. I have uninstalled it , deleted that ums folder from program files but continues always with the same problem.
gambit
Post by gambit »
just checked and no it didnt not install the file in the folder
Hmm I'll look into it
gambit
Post by gambit »
can you tell me where i can download the appropriate mplayer.exe to place in the folder?
Sure, you can get it here
