OSX with Xbox 360, doesnt show up (yet other programs do)
TheCrazedMadman
I've been using Connect360 to stream my movies and music to my xbox 360 from my macbook (10.6.8) for a while now....but the lack of subtitle support is kinda annoying, so I thought I'd try out UMS....so I started it up, selected the folder for my movies...yet it doesnt show up on my xbox (while my connect 360/other programs like this do), are there ports I need to open? Anything else that could prevent the program from showing up? I've attached the debug messages below (note, that the xbox wasnt on at the time, I'll post again when I can, dont wanna wake roommates up, lol)
INFO 2012-09-09 02:25:38.887 [main] Starting Universal Media Server 1.4.0
INFO 2012-09-09 02:25:38.888 [main] Based on PS3 Media Server (ps3mediaserver.org) by shagrath, copyright 2008-2012
INFO 2012-09-09 02:25:38.889 [main] http://www.universalmediaserver.com
INFO 2012-09-09 02:25:38.890 [main] Build: 8d45c4635 (2012-07-18)
INFO 2012-09-09 02:25:38.890 [main] Java: 1.6.0_33-Apple Inc.
INFO 2012-09-09 02:25:38.890 [main] OS: Mac OS X 64-bit 10.6.8
INFO 2012-09-09 02:25:38.891 [main] Encoding: UTF-8
INFO 2012-09-09 02:25:38.891 [main] Memory: 763 MB
INFO 2012-09-09 02:25:38.892 [main] Working directory: /Applications/Universal Media Server.app/Contents/Resources/Java
INFO 2012-09-09 02:25:38.934 [main] Temp folder: /var/folders/vK/vKhyxOOZH2iETHf8DGKKl++++TI/-Tmp-/ps3mediaserver
INFO 2012-09-09 02:25:38.934 [main] Logging config file: /Applications/Universal Media Server.app/Contents/Resources/Java/logback.xml
INFO 2012-09-09 02:25:38.935 [main] debug.log: /Applications/Universal Media Server.app/Contents/Resources/Java/debug.log
INFO 2012-09-09 02:25:38.936 [main]
INFO 2012-09-09 02:25:38.936 [main] Profile directory: /Users/andrewmyers/Library/Application Support/UMS
INFO 2012-09-09 02:25:38.936 [main] Profile path: /Users/andrewmyers/Library/Application Support/UMS/UMS.conf
INFO 2012-09-09 02:25:38.937 [main] Profile status: rw
INFO 2012-09-09 02:25:38.937 [main] Profile name: andrew-myerss-macbook-pro-2.local
INFO 2012-09-09 02:25:38.938 [main]
INFO 2012-09-09 02:25:39.012 [main] Loading MediaInfo library
INFO 2012-09-09 02:25:40.999 [main] Loaded MediaInfoLib - v0.7.58
INFO 2012-09-09 02:25:41.189 [main] Loading renderer configurations from /Applications/Universal Media Server.app/Contents/Resources/Java/renderers
INFO 2012-09-09 02:25:41.229 [main] Loading configuration file: AirPlayer.conf
INFO 2012-09-09 02:25:41.283 [main] Loading configuration file: Android.conf
INFO 2012-09-09 02:25:41.347 [main] Loading configuration file: Bravia4500.conf
INFO 2012-09-09 02:25:41.351 [main] Loading configuration file: Bravia5500.conf
INFO 2012-09-09 02:25:41.368 [main] Loading configuration file: BraviaEX.conf
INFO 2012-09-09 02:25:41.456 [main] Loading configuration file: DirecTVHR.conf
INFO 2012-09-09 02:25:41.496 [main] Loading configuration file: DLinkDSM510.conf
INFO 2012-09-09 02:25:41.572 [main] Loading configuration file: FreeboxHD.conf
INFO 2012-09-09 02:25:41.639 [main] Loading configuration file: FreecomMusicPal.conf
INFO 2012-09-09 02:25:41.674 [main] Loading configuration file: iPad-iPhone.conf
INFO 2012-09-09 02:25:41.729 [main] Loading configuration file: Kuro.conf
INFO 2012-09-09 02:25:41.810 [main] Loading configuration file: LGST600.conf
INFO 2012-09-09 02:25:41.889 [main] Loading configuration file: N900.conf
INFO 2012-09-09 02:25:41.952 [main] Loading configuration file: OPPOBDP83.conf
INFO 2012-09-09 02:25:41.970 [main] Loading configuration file: OPPOBDP93.conf
INFO 2012-09-09 02:25:42.007 [main] Loading configuration file: Panasonic.conf
INFO 2012-09-09 02:25:42.011 [main] Loading configuration file: Philips.conf
INFO 2012-09-09 02:25:42.052 [main] Loading configuration file: PhilipsPFL.conf
INFO 2012-09-09 02:25:42.159 [main] Loading configuration file: PopcornHour.conf
INFO 2012-09-09 02:25:42.212 [main] Loading configuration file: PS3.conf
INFO 2012-09-09 02:25:42.280 [main] Loading configuration file: Realtek.conf
INFO 2012-09-09 02:25:42.372 [main] Loading configuration file: SamsungAllShare.conf
INFO 2012-09-09 02:25:42.419 [main] Loading configuration file: SamsungWiseLink.conf
INFO 2012-09-09 02:25:42.451 [main] Loading configuration file: Showtime3.conf
INFO 2012-09-09 02:25:42.522 [main] Loading configuration file: SonyBluray.conf
INFO 2012-09-09 02:25:42.542 [main] Loading configuration file: Streamium.conf
INFO 2012-09-09 02:25:42.574 [main] Loading configuration file: WDTVLive.conf
INFO 2012-09-09 02:25:42.640 [main] Loading configuration file: WMP.conf
INFO 2012-09-09 02:25:42.686 [main] Loading configuration file: XBMC.conf
INFO 2012-09-09 02:25:42.721 [main] Loading configuration file: XBOX360.conf
INFO 2012-09-09 02:25:42.779 [main] Loading configuration file: YamahaRXV671.conf
INFO 2012-09-09 02:25:42.855 [main] Checking MPlayer font cache. It can take a minute or so.
INFO 2012-09-09 02:26:02.940 [main] Done!
INFO 2012-09-09 02:26:03.023 [main] Searching for plugins in /Applications/Universal Media Server.app/Contents/Resources/Java/plugins
INFO 2012-09-09 02:26:03.024 [main] No plugins found
INFO 2012-09-09 02:26:03.045 [main] Registering transcoding engine: FFmpeg Audio
INFO 2012-09-09 02:26:03.057 [main] Registering transcoding engine: MEncoder
INFO 2012-09-09 02:26:03.057 [main] Registering transcoding engine: FFmpeg
INFO 2012-09-09 02:26:03.058 [main] Registering transcoding engine: MPlayer Audio
INFO 2012-09-09 02:26:03.058 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2012-09-09 02:26:03.059 [main] Registering transcoding engine: MEncoder Web
INFO 2012-09-09 02:26:03.059 [main] Registering transcoding engine: MPlayer Video Dump
INFO 2012-09-09 02:26:03.059 [main] Registering transcoding engine: MPlayer Web
INFO 2012-09-09 02:26:03.061 [main] Registering transcoding engine: tsMuxeR
INFO 2012-09-09 02:26:03.061 [main] Registering transcoding engine: Audio High Fidelity
INFO 2012-09-09 02:26:03.061 [main] Registering transcoding engine: VLC Audio Streaming
INFO 2012-09-09 02:26:03.062 [main] Registering transcoding engine: VLC Video Streaming
INFO 2012-09-09 02:26:03.062 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2012-09-09 02:26:03.188 [main] Using address /5.184.170.131 found on network interface: name:ham0 (ham0)
INFO 2012-09-09 02:26:03.189 [main] Created socket: /5.184.170.131:5001
INFO 2012-09-09 02:26:03.927 [main] Using the following UUID configured in UMS.conf: c1457c55-2f33-4bfc-974f-9b51ef67252c
INFO 2012-09-09 02:26:08.260 [main] The server should now appear on your renderer
INFO 2012-09-09 02:26:36.237 [UPNPHelper] No IP filter specified, access granted to /192.168.1.3
