UMS Does Not See My iMac's Second Drive
ferrarif1355
I have an iMac with 2 internal hard drives. One has the OS and the other I use to hold all my Media. When i try to add my second drive to UMS it won't let me. Is there a work around or something i am doing wrong?
Thanks in advance!
Thanks in advance!
Re: UMS Does Not See My iMac's Second Drive
Hi ferrarif1355!
It's not really a workaround, per se, but not exactly intuitive by Mac standards either.
The way you get to other drives when you click to add a folder on the Navigation tab is to select your main drive in the top drop-down menu (typically "Macintosh HD").
Then scroll down to the "Volumes" folder. You should see all the drives that are currently mounted within that folder.
