Universal Media Server (Select Profile) Does not Exist
Hey everyone, I am using Windows 8.1, I cannot find the Universal Media Server (Select Profile) shortcut in the start menu and due to this I am unable to create/load multiple configuration files. Any help/Advice? I have tried scanning the installation directory and I am unable to find a shortcut for it in there either.
AngelShine
Re: Universal Media Server (Select Profile) Does not Exist
As far as I can tell (I could be wrong) that shortcut is just the same as the default one with the addition of the 'profiles' flag.
I've never used it, but creating a shortcut to your UMS.exe file adding ' profiles' after it should work
Example Target: "C:\Program Files\Universal Media Server\UMS.exe" profiles
