mencoder has a return code of 1
bartekpawlak
I have problems using mencoder convertion in a few last versions of UMS (I am using version 4.1.3 to get mencoder to work). What I see in log file is that "mencoder has a return code of 1". See the attachment, log was generated on the newest version 4.3.1. I use Java8.
Thanks in adavnce for any help.
- (24.47 KiB) Downloaded 696 times
Re: mencoder has a return code of 1
You might need to uninstall some firewalls if you took some.
theflowgamer
I have exactly the same issue. When I copy the command and run it in console the output is "FATAL: Cannot initialize video driver". The ffmpeg works fine though. I guess that there is an invalid combination of parameters configuring video codec.
- Optimus_prime
I will have a look into it myself, Sorry i would've reply'd sooner but i've been away. Which versions are having the issue so i can test them all
maybe this will fix the *.mkv problem on my ps3 too! it would be sooo good...
Hi
Can you please provide logs from the last working version of UMS, playing the same file?
