UMS in Headless Mode, how to find debug-file?
I am running UMS in headless mode with ubuntu 14.04.
I have several problems (audio not sync to movie, gpu acceleration seems not working) but I dont find a debug file in my folder.
Could anyone guide me how to enter debugging / loggin?
UMS was set up according to these instructions:
http://www.slsmk.com/how-to-install-uni ... less-mode/
I dont find the log / debug in /opt/ums/... ?
thanking you in advance,
Johannes
Johannes
Re: UMS in Headless Mode, how to find debug-file?
I think this is the default location: /tmp/universalmediaserver/debug.log
Br
Holger
Br
Holger
Thanks, ...but /tmp/universalmediaserver/ is empty, any other idea?
Regards,
Johannes
Regards,
Johannes
Agent_Rocket
according to logback.headless.xml found in the ums installation, it's "either the current directory or (when that is read only) the system temp directory."
twistedLucidity
On my Ubuntu 14.04.1 test install, it was located under ~/config/UMS
This was when starting it from the shell script directly
I think that's a poor location, /var/log or /tmp/universalmediacenter might be better.
Log files can get thrashed.
