Memory leak?
Memory leak?
Hello
Using 4.3.1 win7 latest java, ps3
Last night I found javaw.exe process with over 1GB of memory, shut down UMS and it dumped. Turned on UMS this morning and after getting home its up to 457MB and growing at about16kB/m idle... is this normal?
Also, unrelated issue, folders disappear for some reason. Need to quit(not restart) server to see them... probably already reported but thought I would just say "me too".
- AYColumbia
Re: Memory leak?
I can confirm this issue. I watched a few shows via UMS yesterday and afterwards the java executable was using 1G of RAM. To free it, I did the same, i.e., quit UMS and restarted it.
Re: Memory leak?
That's normal for any Java program, it's just how Java manages its memory. If your computer is running out of memory, Java should detect that and release it.
