[Solved] javaw.exe - high memory load
René
Post by René »
Hello, I have a big problem for about some days. I have older PC, Interl Core E7300, 4GB RAM etc, win 7 x64 etc. Using UMS 5.0.0 and after 10-15 minutes of watching TV shows, video and audio are intermittent. I see javaw.exe has high load in task manager. have you got any solution please?
Screenshot: https://dl.dropboxusercontent.com/u/198 ... %A1zvu.png
Thank you
jj123
Re: javaw.exe - high memory load
Post by jj123 »
This is normal behaviour for Java applications.
The freeing of memory is handled by the garbage collector, which will free memory when it decides to.
Thanks for the post. Like jj123 said it's normal, the good news is that Java will free the memory if another program wants it so there is no problem.
