DTS sync issues
chamelious
DTS sync issues
This an issue i've had for years, still present in 5.0. Wondered if anyone could shed any light?
Client device is a <1 year old Samsung 5 series TV.
Issue can sometimes be resolved with the "audio delay" option on my tvs options, sometimes the 250ms available is not enough, or maybe the sync problem goes in the opposite direction.
Is this just maybe down to the power of the device running UMS?
Some more info, files are kept on external usb2 disk, bandwidth issue maybe?
Re: DTS sync issues
Hi chamelious, which TV is it? Can you please post logs following the Problem Reporting Guidelines?
chamelious
Re: DTS sync issues
TV is a samsung ue55h6400 and yes apologies will post some logs this eve.
