Trend micro thinks all installers after 4.3.1 behave suspiciously?
blue000000
Long time user. all previous versions from 4.3.1 and before, install just fine.
i tested 4.4.0-Java7, 4.4.0-Java8, 5.0.0-Java8, 5.0.1-Java8, and during the "searching" part where i think its scanning the computer, Trend micro kills the program and deletes the installer. it calls its a HEU_AEGISCS219.
It says the installer was trying to do something to "C:\Windows\System32\rundll32.exe".. what was it trying to do?
- Optimus_prime
Re: Trend micro thinks all installers after 4.3.1 behave suspiciously?
I'm using Trend Micro as well and am seeing the same issue. If you unblock it in trend micro, it should install. It's a false positive and we will get trend micro to amend the issue
blue000000
thanks for the confirmation thats its a false positive. is there anything i need to do for you to get it resolved with Trend?
- Optimus_prime
Update on the trend issue, I've been in contact with trend over the last tree weeks and have now been bumped up to a Level 2 support case due the nature of the issue.
hopefully it gets sorted soon
blue000000
Did they ever respond?
blue000000
somewhere between 4.3.1 and 5.2.1 this issue has been resolved.
