OS X Memory Leak V5.*_J*
This provides more testing details from the post in the Mac forum.
The first log is of a 21.4 GB file. Inactive Memory:
The second log is of 3.24 GB file, Inactive Memory:
During this capture additional issues arose which may be seen in the same log files:
- admin privilege required for incoming connection
- no thumbnails
Other issues will be posted as separate topics.
- 1 h - 9.8 GB
2 h - 16.5 GB
End (2 h 33 m) - 20.5 GB
- 30 m - 2.3 GB
End (56 m) - 3.3 GB
- no thumbnails
- ums_dbg#2_3GB_File.zip
- Short file 3 Gb
- (39.45 KiB) Downloaded 426 times
- ums_dbg#1_501_J7_MemLk_NoThumb.zip
- Big file 21 GB
- (11.67 KiB) Downloaded 403 times
. . . . and a few others.
Samsung UN55C8000
Samsung UN55C8000
Re: OS X Memory Leak V5.1.0J6
Tested 5.1.0 Java 6
Same problem with Inactive Memory not being released. It is proportional to the size of the video file.
Going to look at Java 8 too.
Log provided if requested.
Samsung UN55C8000
Samsung UN55C8000
Re: OS X Memory Leak V5.*_J*
This is still an issue in 5.1.0 J6 & 8
Samsung UN55C8000
Samsung UN55C8000
