ums will not start
poolshark691
ums will not start
i have an xbox one and 360 i used to use pms but that stopped working now ive tried ums but it doesnt start it tries to but then stops here is the log hope it helps
<?xml version="1.0"?>
-<configuration debug="true">
<!-- See http://logback.qos.ch/manual/ for more information on how to configure the Logback logging engine. Available levels: ALL < TRACE < DEBUG < INFO < WARN < ERROR < OFF -->
<!-- Let PMS decide the path for the logfile: either the current directory or (when that is read only) the system temp directory. -->
<define class="net.pms.logging.DebugLogPathDefiner" name="debugLogPath"/>
<!-- Appender for messages in the PMS "Traces" tab -->
-<appender class="net.pms.logging.FrameAppender" name="traces">
<!-- Only log INFO and higher -->
-<filter class="ch.qos.logback.classic.filter.ThresholdFilter">
<level>INFO</level>
</filter>
-<encoder class="ch.qos.logback.classic.encoder.PatternLayoutEncoder">
<pattern>%-5level %d{HH:mm:ss.SSS} [%thread] %msg%n</pattern>
</encoder>
</appender>
<!-- Appender for the console -->
-<appender class="ch.qos.logback.core.ConsoleAppender" name="console">
<level>INFO</level>
</filter>
</encoder>
</appender>
<!-- Appender for the debug.log that will keep the file growing in size until PMS is restarted. -->
-<appender class="ch.qos.logback.core.FileAppender" name="debug.log">
<!-- No threshold filtering, log everything the root logger allows -->
<file>${debugLogPath}${file.separator}debug.log</file>
<append>false</append>
<!-- Start new debug.log on each application start -->
</encoder>
</appender>
<!-- Appender for the debug.log that will roll the debug.log file after 10 MBytes and will keep a maximum of 5 old and compressed logs. -->
-<appender class="ch.qos.logback.core.rolling.RollingFileAppender" name="debug.log.10MB">
-<rollingPolicy class="ch.qos.logback.core.rolling.FixedWindowRollingPolicy">
<fileNamePattern>${debugLogPath}debug.log.%i.zip</fileNamePattern>
<minIndex>1</minIndex>
<maxIndex>5</maxIndex>
</rollingPolicy>
-<triggeringPolicy class="ch.qos.logback.core.rolling.SizeBasedTriggeringPolicy">
<maxFileSize>10MB</maxFileSize>
</triggeringPolicy>
</encoder>
</appender>
<!-- For debugging purposes it can be handy to define custom levels for specific classes or packages. For example: <logger name="net.pms.dlna.DLNAResource" level="ALL" /> <logger name="net.pms.network.RequestHandlerV2" level="ALL" /> <logger name="net.pms.util" level="ALL" /> -->
<!-- silence noise from external libraries -->
<logger name="org.apache" level="WARN"/>
<logger name="httpclient.wire" level="WARN"/>
<!-- Root logger defines the minimum log level for all loggers -->
-<root level="DEBUG">
<appender-ref ref="traces"/>
<appender-ref ref="console"/>
<!-- If unlimited growth of debug.log is not desired use the appender-ref "debug.log.10MB" instead of "debug.log". -->
<appender-ref ref="debug.log"/>
<!-- <appender-ref ref="debug.log.10MB" /> -->
</root>
</configuration>
<level>INFO</level>
</filter>
</encoder>
</appender>
<level>INFO</level>
</filter>
</encoder>
</appender>
</encoder>
</appender>
</rollingPolicy>
</triggeringPolicy>
</encoder>
</appender>
</root>
</configuration>
