Oppo BDP-93 UMS 5.1.0, mkv shown as mpeg
I've had UMS 4.1.3 working fine with my Oppo BDP-93 for a while now but after installing 5.1.0 (and a few other versions past 4.1.3) my mkv files are showing up as mpeg. Is this because of a problem/change in the renderer config file?
Version 4.1.3 appears to use OPPOBDP93.conf
and 5.1.0 OPPO-BDP.conf
If it matters, in the Transcoding Settings tab I also put mkv in the Skip transcoding... section. Should it be .mkv instead?
The odd thing is that one or two or so mkvs show up as mkv, not mpeg. I can not tell what's different about those.
If this is actually a bug rather than just a renderer config problem, please let me know and I'll include logs if wanted.
Thanks!
# Profile for OPPO BDPs.
RendererName=OPPO BDP
UserAgentSearch=OPPO PLAYER
Video=true
Audio=true
Image=true
SeekByTime=false
TranscodeVideo=MPEGPS-MPEG2-AC3
TranscodeAudio=LPCM
DefaultVBVBufSize=true
MuxH264ToMpegTS=true
MuxDTSToMpeg=true
WrapDTSIntoPCM=false
MuxLPCMToMpeg=false
MaxVideoBitrateMbps=0
MaxVideoWidth=1920
MaxVideoHeight=1080
H264Level41Limited=false
TranscodeExtensions=iso,vob
StreamExtensions= gif,jpg,png,aac,flac,m4a,mp3,pcm,wav,wma,avi,mkv,mp4,m2ts,ts,wmv
MediaInfo=true
RendererName = OPPO BDP
UserAgentSearch = OPPO PLAYER
DefaultVBVBufSize = true
TranscodeExtensions = iso,vob
StreamExtensions = gif,jpg,png,aac,flac,m4a,mp3,pcm,wav,wma,avi,mkv,mp4,m2ts,ts,wmv
MediaInfo = true
Thanks!
Re: Oppo BDP-93 UMS 5.1.0, mkv shown as mpeg
I don't know exactly what it does, but I changed MediaInfo = from 'true'
to 'false' and mkv's now show up as mkv. Things seem to be working...?
Any insight on this?
Thank you!
Thank you!
After more searching, I think that if MediaInfo = true, then I have to have some Supported types in the OPPO-BDP.conf file. Is that correct?
I found this post, viewtopic.php?t=36&start=10#p5886, with some Supported formats for Oppo.
I put them in my OPPO-BDP.conf file so it looks like
I also read the DefaultRenderer.conf that said the order matters so I tried with the 'Supported = f:mkv ...' line first. No matter what my mkv files show up on my Oppo as mpeg. Only setting MediaInfo = false lets the Oppo see mkv files as mkv.
The files actually play either way (don't know if it's being transcoded or not), I think, so I'm assuming this is a renderer config problem and not a bug?
Can anybody help?
Thank you!
MediaInfo = true
# --- video ---
Supported = f:mpegps|mpegts v:mpeg1|mpeg2 a:ac3|dts|lpcm|mpa|mp3 m:video/mpeg
Supported = f:mpegts v:h264|vc1 a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3 m:video/vnd.dlna.mpeg-tts
Supported = f:mp4|mov|QT v:mp4|h264 a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3 m:video/mp4
Supported = f:mpeg|mpg|dat|vob v:mpeg1|mpeg2 a:ac3|dts|lpcm|mpa|mp3 m:video/mpeg
Supported = f:m2t|m2ts|ts v:mp4|mpeg2|h264|vc1 a:aac|ac3|dts|lpcm|mpa|mp3 m:video/mpeg
Supported = f:ogm v:mp4|mpeg2|h264|wmv a:ac3|dts|lpcm|mpa|mp3 m:video/mpeg
######### NON-US MODELS: CHANGE THE FOLLOWING 2 MIME-TYPES TO m:video/divx
Supported = f:avi|divx|xvid v:divx|mp4|mpeg2|h264|vc1|wmv a:ac3|lpcm|mp2|mp3|dts|wma m:video/avi
Supported = f:mkv v:mpeg2|mp4|divx|h264|vc1 a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3 m:video/x-matroska
Supported = f:wmv v:mp4|wmv|vc1 a:ac3|wma|lpcm|mp3|mpa m:video/x-ms-wmv
Supported = f:asf v:mp4|wmv|vc1 a:ac3|wma|lpcm|mp3|mpa m:video/x-ms-asf
Can anybody help?
Thank you!
