Vinyl-rip FLAC plays slowly
Hi guys,
I'm hoping someone can help me out with this minor issue I am having.
Basically all FLAC files which are vinyl rips are playing slowly - it's a bit like when you put a 45rpm vinyl to play at 33rpm.
First I thought it's my home PC which is not powerful enough to process, but my work laptop (2xcore i7) also does the same.
Running UMS 5.1.1 on Windowx XP (PC) and Windows 7 (laptop), all connected via ethernet to my PS3.
Log snippet when I tried to play one of the vinyl FLACs:
Any advice would be appreciated, thanks
DEBUG 10:59:55.654 [New I/O worker #8] Starting transcode/remux of 06 Another Day In Paradise.flac with media info: container: flac, bitrate: 2790723, size: 112046118, video codec: und, duration: 00:05:21.00, width: 0, height: 0, frame rate: null, thumb size : 535365, muxing mode: null, mime type: null, matrix coefficients: null, attached fonts: false
Audio track id: 0, lang: und, flavor: , audio codec: flac, sample frequency:96000, number of channels: 2, bits per sample: 24, artist: Phil Collins, album: But Seriously, song name: Another Day In Paradise, year: 0, track: 6
DEBUG 10:59:55.654 [New I/O worker #8] Reading TranscodeFastStart: true (default: false)
DEBUG 10:59:55.654 [New I/O worker #8] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 10:59:55.654 [ffmpeg64.exe-2] Starting C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe -loglevel warning -i C:\Users\Music\Phil Collins - But Seriously\06 Another Day In Paradise.flac -f s16be pipe:
DEBUG 10:59:55.667 [ffmpeg64.exe-2] Attaching thread: ffmpeg64.exe-2
DEBUG 10:59:55.672 [ffmpeg64.exe-2-Timer] Created playback timer for PlayStation 3
INFO 10:59:56.166 [StartPlaying Event] Started playing 06 Another Day In Paradise.flac on your PlayStation 3
DEBUG 10:59:56.166 [StartPlaying Event] The full filename of which is: C:\Users\Music\Phil Collins - But Seriously\06 Another Day In Paradise.flac and the address of the renderer is:
DEBUG 11:00:13.324 [New I/O worker #6] Setting InputStream new position to: 2,288,512
DEBUG 11:00:31.022 [cling-5] found device: MediaServer (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:b1a64cfe-43a2-4cde-a4c4-0493d21b29a5, Descriptor: http://:5001/description/fetch, Root: true
DEBUG 11:00:31.344 [ffmpeg64.exe-2-Cleanup] Stopping process: ffmpeg64.exe-2
INFO 11:00:32.844 [StopPlaying Event] Stopped playing 06 Another Day In Paradise.flac on your PlayStation 3
DEBUG 11:00:32.844 [StopPlaying Event] The full filename of which is: C:\Users\nakkiran\Music\Phil Collins - But Seriously\06 Another Day In Paradise.flac and the address of the renderer is:
