[Solved] 5.1.2 J8 Accepts then Rejects Renderer, Files
--- This is a dup with the log file attached ---
Edited: reran and captured bad and good logs (times don't match the code inserts).
More testing and looking at the log file turned this up - after successfully ID'ing the renderer - it marks it unrecognized:
After packing the debug file, I selected "Restart Server" and all the error messages went away and the file played:
TRACE 16:03:25.830 [cling-11] Matched media renderer "Samsung C/D Series" based on address /10.0.1.89
DEBUG 16:03:25.832 [cling-11] Reading UpnpDetailsSearch: "Samsung , [CD]S?\d{3}\d? , AllShare" (default: "")
DEBUG 16:03:25.832 [cling-11] Reading MediaInfo: true (default: false)
DEBUG 16:03:25.832 [cling-11] Marking upnp renderer "TV-55C8000" at /10.0.1.89 as unrecognized
DEBUG 16:03:25.833 [cling-11] Purging renderer Samsung C/D Series as invalidCode: Select all
04-20 16:04:31 Media renderer was not recognized. Possible identifying HTTP headers:User-Agent: DLNADOC/1.50
04-20 16:05:12 Started playing Absolute Power.mkv on your TV-55C8000
04-20 16:05:16 Media renderer was not recognized. Possible identifying HTTP headers:User-Agent: DLNADOC/1.50
04-20 16:05:18 Media renderer was not recognized. Possible identifying HTTP headers:User-Agent: DLNADOC/1.50
04-20 16:05:19 Media renderer was not recognized. Possible identifying HTTP headers:User-Agent: DLNADOC/1.50
04-20 16:05:19 Checking shared folder: /Users/umsmkv/aML/Video/Index
04-20 16:46:06 Sending BYEBYE...
04-20 16:46:06 Stopping server on host 10.0.1.50 and port 5001...
04-20 16:46:07 Using address /10.0.1.50 found on network interface: name:en0 (en0)
04-20 16:46:07 Created socket: /10.0.1.50:5001
04-20 16:49:56 Checking shared folder: /Users/umsmkv/aML/Video/Index
04-20 16:50:10 The file /Users/umsmkv/aML/Video/Index/Blu-ray/M*A*S*H (MASH| 1970).mkv could not be parsed. It will be hidden
04-20 16:50:20 Started playing Absolute Power.mkv on your TV-55C8000- Attachments
- ums_dbg-33_512J8_Unrecognized.zip
- (81.86 KiB) Downloaded 430 times
. . . . and a few others.
Samsung UN55C8000
Samsung UN55C8000
Re: 5.1.2 J8 Accepts then Rejects Renderer, Files
In renderers/Samsung-CD.conf try changingmichaelt wrote: after successfully ID'ing the renderer - it marks it unrecognized
UpnpDetailsSearch = Samsung , [CD]S?\d{3}\d? , AllShareCode: Select all
UpnpDetailsSearch = [CD]S?\d{3}\d? , (Samsung|AllShare)Re: 5.1.2 J8 Accepts then Rejects Renderer, Files
I'll give it a try although this set has never had a firmware update since I bought it.infidel wrote:Your 55C8000's upnp device details are formatted in a way that's new to UMS (probably due to Samsung firmware changes) and causing UMS to doubt its initial recognition.
Yup - seems to be good now.
Thanx
Samsung UN55C8000
Samsung UN55C8000
Re: [Solved] 5.1.2 J8 Accepts then Rejects Renderer, Files
I should have said its upnp details aren't consistent with other Samsung c/d tvs we've seen before and left it at thatmichaelt wrote:although this set has never had a firmware update since I bought it.
Now that sounds more like the real world - trial & guess.infidel wrote:I should have said its upnp details aren't consistent with other Samsung c/d tvs we've seen before and left it at that. There's no real standard for how devices present their identifying info, so recognition is a big headache.
Edit:
Real reason was the in the .conf file: changed "UpnpDetailsSearch" to:
[CD]S?\d{3}\d? , (Samsung|AllShare)MacPro5,1 - 2.8 GHz, 32 GB, 20TB, OS X 10.11.6,
Samsung UN55C8000
Samsung UN55C8000
