DVDISO including multibyte can't be delivered
UMS5.1.2 most recent release version.
When containing the multi- byte string in the file path is not encoded in Mencoder, it is not possible to play the video in DLNA.
It is not possible to deploy DVDISO in DLNA client .
All the file path can be reproduced correctly when tested by changing the single-byte character string .
Might Mencoder problems Maybe , but could be reproduced without any problem when the PMS.
Although I tried because there was described as was resolved by changing the Mencoder to the old version in the past of the topic , even in single-byte string and replace the Mencoder, multi-byte character string was not able to play .
Replace all the multi-byte string please tell someone solution so nonsense .
