Problem with DTS / LPCM sound.
MarkKiss
Post by MarkKiss »
Hello, and first thanks for amazing UMS.
U have big problem with DTS/LPCM sound
I play at SONY PS3 + SONY STR-DA3600ES + PANASONIC VT65
Server is Xeon E3 3.1Ghz 16Gb Ram Windows 2008 R2 Java 8 UMS 5.1.3
I tested from few BluRay Disk DTS/DTS-HD-MA/Dolby TrueHD all play well and PS3 show correct info about audio stream same AMP showing correct info about audio stream
When I try play any DTS trough UMS it don't work. I downloaded your VideoTestingSuite and make test with all 3 file with DTS
1. MKV-H264-DTS-6ch PS3 say is LPCM 2.0Ch 48Khz 1.5Mbps ( AMP say no stream = no sound )
2. MKV-H265-DTS-6ch PS3 say is DolbyDigital 5.1Ch 48Khz 640kbps ( AMP say LPCM 5.1 )
3. MKV-XVID-DTS-6ch PS3 say is DolbyDigital 5.1Ch 48Khz 640kbps ( AMP say LPCM 5.1 )
In attach are two file with debug
One with enabled " USE LPCM for audio " second without
Both have " Encoded audio passthrough for AC-3 and DTS"
( but i was trying all combination KEEP DTS / AC-3 enabled disabled etc. )
I make test with same file play at KODI ( Raspberry Pi ) with DTS play perfect ( without UMS ).
Under line
AMP STR-DA3600ES isnt correctly detected ( sometimes is detect like D-Link 510 ) and almost all what i try dont play
I dont use so for me isnt important.
Many Thanks for help
(74.14 KiB) Downloaded 545 times
ums_dbg_2.zip
(71.86 KiB) Downloaded 571 times
MarkKiss
Re: Problem with DTS / LPCM sound.
Post by MarkKiss »
I make today test with old PS3 Media Server 1.9 and all works fine ( i mean DTS sound and LPCM )
MarkKiss
Post by MarkKiss »
Bump.
Any help / idea ?
Supermanfan77
Post by Supermanfan77 »
I had a problem with a movie which had TrueHD 7.1 audio. After deselecting the pass-through option it played just fine. Try that would be my suggestion.
