Predefined XML entities
I'm new to UMS, but I allready quite like it. I use just one DLNA client, an Onkyo TX-NR807 - so I only use Audio. I had some problems getting flac to work with the supplied Onkyo (NR717) renderer profile, but I've been able to make my own which is currently playing both mp3 and flac correctly at least. I'll work further on it and post it if I find some relevant place to do that when I consider it "finished".
But, I have one problem that I can't seem to figure out. UMS encodes the text it sends to my Onkyo with HTML character entity (eg & apos ; for ' ), which the Onkyo doesn't understand and just writes out like any other text. The results are hard to read. I don't know what the DLNA standard says about text encoding, but serviio did this correct (although not much more
) for my Onkyo. Is there anywhere, in the renderer config or elsewhere, where I can specify this encoding? I'm guessing UTF-8 would work fine, since I've seen it being able to display special nordic characters from serviio without problems.
Nadar
Nadar
Re: HTML character entity
I downloaded the source, installed Eclipse and Maven and started to trace.... and found the problem (after first checking that texts are being stored correcly in the H2 database): In DNLAResource.java i changed the folloing lines and this fixes the issue as far as I can see:
Every Title, Artist, Album etc is ran through encodeXML(). I certainly don't think this is a real "fix", but it's where the problem lies.
addXMLTagAndAttribute(
sb,
"dc:title",
mediaRenderer.getDcTitle(title, nameSuffix, this)
//encodeXML(mediaRenderer.getDcTitle(title, nameSuffix, this))
//TODO: TEMP
wireshark.append("\"").append(title).append("\"");
if (firstAudioTrack != null) {
if (StringUtils.isNotBlank(firstAudioTrack.getAlbum())) {
addXMLTagAndAttribute(sb, "upnp:album", firstAudioTrack.getAlbum());
//addXMLTagAndAttribute(sb, "upnp:album", encodeXML(firstAudioTrack.getAlbum()));
if (StringUtils.isNotBlank(firstAudioTrack.getArtist())) {
addXMLTagAndAttribute(sb, "upnp:artist",firstAudioTrack.getArtist());
//addXMLTagAndAttribute(sb, "upnp:artist", encodeXML(firstAudioTrack.getArtist()));
addXMLTagAndAttribute(sb, "dc:creator", firstAudioTrack.getArtist());
//addXMLTagAndAttribute(sb, "dc:creator", encodeXML(firstAudioTrack.getArtist()));
if (StringUtils.isNotBlank(firstAudioTrack.getGenre())) {
addXMLTagAndAttribute(sb, "upnp:genre", firstAudioTrack.getGenre());
//addXMLTagAndAttribute(sb, "upnp:genre", encodeXML(firstAudioTrack.getGenre()));
if (firstAudioTrack.getTrack() > 0) {
addXMLTagAndAttribute(sb, "upnp:originalTrackNumber", "" + firstAudioTrack.getTrack());
I'm not sure why I don't get any reply. Can someone at least tell me what I'm doing wrong?
I could submit a bug report, but I'm not sure if it is a bug. I don't have ISO/IEC 29341-3-12:2008 that specifies this communication (if I figured it correctly), and I'm not going to buy the specification just to find out. I'd really appreciate if someone could shed some light on whether UMS or Onkyo is off spec here.
Re: Predefined XML entities
As anyone that knows XML and read this thread will understand, I'm not very familiar with XML
I finally figured out that these are not HTML character entities, but XML predefined entities and is a part of the XML standard itself. Once I figured that out, things became clearer to me. Everything send to a XML document have to be encoded with these entities per definition.
That led me to look again, and I also found the problem. Forget the code above, everything is fine in DNLAResource.java, the problem is in StringUtil.java. The ampersand (&) is escaped twice, creating all sort of problems and this is definitly a bug. The ampersand obviously has to be escaped first since all the other escapes will include one, and it is, but it's also escaped once again last. That's the problem/bug. I removed the last encoding, and now everything shows correctly at my Onkyo:
That means that this is definitly a bug, and I should probably submit it somewhere.
public static String encodeXML(String s) {
s = s.replace("&", "&");
s = s.replace("<", "<");
s = s.replace(">", ">");
s = s.replace("\"", """);
s = s.replace("'", "'");
//s = s.replace("&", "&");
return s;
Thanks for that finding. I commited that change.
I already did a fork and was preparing a pull request, but that's not needed anymore now. I've have a couple of other minor things I will do a pull request for though, but I'm still working on that.
