Newbie advice ?
Newbie advice ?
First of all, thanks for all the work you've done over time and, not least, the big improvement I at least
have experience with this new version. Speed / browsing have increased noticably !!
Just a quick question that I fail to find an answer to,
I've been using 2 install during the PMS period,
each servicing different media and both having their own IP restrictions.
I've done this by having 2 installations of PMS and using the secondary install with start option
PROFILES and then manually choosing another pms.conf for that instance.
Is there a way of adjusting the .bat files so that one could have
one install only and instead having 2 different .bat files each pointing to it's own .conf file ?
Or, if not else, having 2 different installs but still having the .bat files pointing directly to "it's own" .conf file
and thereby not having to choose it manually on each startup ?
Thanks again,
Thanks again,
