Youtube.. what's the best way..
Hey..
Ive tried adding some youtube playlists to the web.conf and they show up with thumbnails, but playback fails (Vlc player)
I've tried disbaling VLC player in engines and save+ restart, but that does not change anything.. it seems it's always VLC engine handling WEB streams..no matter what engine is turn on/off.
So.. how do you guys do this?..play youtube content.. adding your playlists etc etc.
- SharkHunter
- Developer
Re: Youtube.. what's the best way..
If you ask me you should of course use Channels. There you'll get all you're YouTube subscriptions and favoirtes in nice folders. You'll even get some categories support.
Simply install and try it out. You need to create a UMS.cred file (in the same dir as your UMS.conf) and add chanles.YouTube=user,pwd.
Ok,thanks i've installed the channels plugin..
On my TV it now show the channel plugin and inside some folders.. but where to find content? add playlists and stuff? =)
Edit: And whats the "unlock everything" ?
- SharkHunter
- Developer
How did you install the Plugin? Copied the jar file or did you use the plugin installer?squadjot wrote:Ok,thanks i've installed the channels plugin..
Upload some logs and we'll see what wnet wrong (if anything).
The "unlock everything" can safely be ignored for now...It has to do with "illegal/blocked" channels to do, a sort of parental control...
Hi i installed the plugin via the UMS built-in plugin installer..
I tried the playlists that didnt work before.. (but not in channels folder) - they now work!.. and i see PMS encoder as transcoding engine (instead of VLCPlayer)
So..the rest is just adding my You tube playlists to the WEB.conf?..
Don't know what i was expecting.. maybe some sort of oncreen search functionality?.. (tho it always sucks searching by remote)..
Also..right now, i'm not sure using channels correctly/fully..??
until now it just made my current web.conf playable (or the content i added to it)
You understand?
OT i tried the grooveshark plugin, alltho none of the songs worked , the search functionality was pretty clever.. (it might work better now where i installed channels)
Edit: "Parental lock" would be better (if thats the case) .."Unlock Everything" <-- leaves me with a feeling i'm missing out on something =)??..free movies?.. free pron??..free money??..free weed?..gold?..diamonds!!
You understand?
- SharkHunter
- Developer
No need to add anything. You should see a "YouTube" folder in the Channels folder. If you to the UMS.cred file add your username and pwd you'll get your YouTube playlists automatically there.
Works fro me at least.
GrooveShark might have changed something again. I'll have a look.
Oke, after poking a bit, (tried pressing update/ and refresh plugsin a couple of times)- THEN alot of folders showed up..CANAL+, TV3, Youtube etcetc..
But when i go into YouTube folder.. i still don't see my favorites, or any other playable content. Offcourse tried poking my cred file..
user@gmail.com,pass
hmmm, dunno what it is
edit: Should i be looking in Channels/YouTube/MyTube/Favorites/ <--?
user@gmail.com,pass
- SharkHunter
- Developer
Yes that's where. Or Channels/YouTube/MyTube/Subscriptionssquadjot wrote:Oke, after poking a bit, (tried pressing update/ and refresh plugsin a couple of times)- THEN alot of folders showed up..CANAL+, TV3, Youtube etcetc..
user@gmail.com,pass
Damn.. nothing..
DEBUG 2012-11-16 19:54:02.220 [main] My PID is 2836
INFO 2012-11-16 19:54:04.810 [main] An invalid plugin was ignored
INFO 2012-11-16 19:54:05.606 [main] Starting Universal Media Server 2.0.0
INFO 2012-11-16 19:54:05.637 [main] Based on PS3 Media Server by shagrath, copyright 2008-2012
INFO 2012-11-16 19:54:05.652 [main] http://www.universalmediaserver.com
INFO 2012-11-16 19:54:05.652 [main] Build: 9456e1544 (2012-10-31)
INFO 2012-11-16 19:54:05.652 [main] Java: 1.7.0_05-Oracle Corporation
INFO 2012-11-16 19:54:05.652 [main] OS: Windows 7 32-bit 6.1
INFO 2012-11-16 19:54:05.668 [main] Encoding: UTF-8
INFO 2012-11-16 19:54:05.668 [main] Memory: 742 MB
INFO 2012-11-16 19:54:05.668 [main] Working directory: C:\Program Files\Universal Media Server
INFO 2012-11-16 19:54:05.684 [main] Temp directory: C:\Users\jot\AppData\Local\Temp\universalmediaserver
INFO 2012-11-16 19:54:05.684 [main] Logging config file: C:\Program Files\Universal Media Server\logback.xml
INFO 2012-11-16 19:54:05.684 [main] debug.log: C:\Program Files\Universal Media Server\debug.log
INFO 2012-11-16 19:54:05.699 [main] Profile directory: C:\ProgramData\UMS
INFO 2012-11-16 19:54:05.699 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO 2012-11-16 19:54:05.699 [main] Profile permissions: rw
INFO 2012-11-16 19:54:05.699 [main] Profile name: ATOM
INFO 2012-11-16 19:54:05.715 [main] Loading MediaInfo library
INFO 2012-11-16 19:54:05.980 [main] Loaded MediaInfoLib - v0.7.61
INFO 2012-11-16 19:54:06.011 [main] Loading renderer configurations from C:\Program Files\Universal Media Server\renderers
INFO 2012-11-16 19:54:06.011 [main] Loading configuration file: AirPlayer.conf
INFO 2012-11-16 19:54:06.027 [main] Loading configuration file: Android.conf
INFO 2012-11-16 19:54:06.027 [main] Loading configuration file: Bravia4500.conf
INFO 2012-11-16 19:54:06.042 [main] Loading configuration file: Bravia5500.conf
INFO 2012-11-16 19:54:06.042 [main] Loading configuration file: BraviaEX.conf
INFO 2012-11-16 19:54:06.058 [main] Loading configuration file: DirecTVHR.conf
INFO 2012-11-16 19:54:06.058 [main] Loading configuration file: DLinkDSM510.conf
INFO 2012-11-16 19:54:06.074 [main] Loading configuration file: FreeboxHD.conf
INFO 2012-11-16 19:54:06.074 [main] Loading configuration file: FreecomMusicPal.conf
INFO 2012-11-16 19:54:06.074 [main] Loading configuration file: iPad-iPhone.conf
INFO 2012-11-16 19:54:06.089 [main] Loading configuration file: Kuro.conf
INFO 2012-11-16 19:54:06.105 [main] Loading configuration file: LGST600.conf
INFO 2012-11-16 19:54:06.105 [main] Loading configuration file: N900.conf
INFO 2012-11-16 19:54:06.120 [main] Loading configuration file: OPPOBDP83.conf
INFO 2012-11-16 19:54:06.120 [main] Loading configuration file: OPPOBDP93.conf
INFO 2012-11-16 19:54:06.120 [main] Loading configuration file: Panasonic.conf
INFO 2012-11-16 19:54:06.136 [main] Loading configuration file: Philips.conf
INFO 2012-11-16 19:54:06.152 [main] Loading configuration file: PhilipsPFL.conf
INFO 2012-11-16 19:54:06.152 [main] Loading configuration file: PopcornHour.conf
INFO 2012-11-16 19:54:06.152 [main] Loading configuration file: PS3.conf
INFO 2012-11-16 19:54:06.167 [main] Loading configuration file: Realtek.conf
INFO 2012-11-16 19:54:06.167 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO 2012-11-16 19:54:06.183 [main] Loading configuration file: SamsungAllShare.conf
INFO 2012-11-16 19:54:06.183 [main] Loading configuration file: SamsungWiseLink.conf
INFO 2012-11-16 19:54:06.183 [main] Loading configuration file: Showtime3.conf
INFO 2012-11-16 19:54:06.198 [main] Loading configuration file: SMP-N100.conf
INFO 2012-11-16 19:54:06.198 [main] Loading configuration file: SonyBluray.conf
INFO 2012-11-16 19:54:06.214 [main] Loading configuration file: SonyBraviaHX800.conf
INFO 2012-11-16 19:54:06.214 [main] Loading configuration file: Streamium.conf
INFO 2012-11-16 19:54:06.214 [main] Loading configuration file: WDTVLive.conf
INFO 2012-11-16 19:54:06.214 [main] Loading configuration file: WMP.conf
INFO 2012-11-16 19:54:06.230 [main] Loading configuration file: XBMC.conf
INFO 2012-11-16 19:54:06.230 [main] Loading configuration file: XBOX360.conf
INFO 2012-11-16 19:54:06.230 [main] Loading configuration file: YamahaRXA1010.conf
INFO 2012-11-16 19:54:06.230 [main] Loading configuration file: YamahaRXV671.conf
INFO 2012-11-16 19:54:06.261 [main] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-11-16 19:54:06.261 [main] launching: win32/mplayer.exe
DEBUG 2012-11-16 19:54:06.431 [main] launching: win32/mplayer.exe
INFO 2012-11-16 19:54:06.605 [main] Done!
INFO 2012-11-16 19:54:06.605 [main] Found AviSynth plugins dir: C:\Program Files\AviSynth\plugins
INFO 2012-11-16 19:54:06.605 [main] VSFilter.dll is not in the AviSynth plugins directory. This can cause problems when trying to play subtitled videos with AviSynth
INFO 2012-11-16 19:54:06.605 [main] Found VideoLAN version 2.0.3 at: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2012-11-16 19:54:06.620 [main] Searching for plugins in C:\Program Files\Universal Media Server\plugins
INFO 2012-11-16 19:54:06.651 [main] Found plugin: net.pms.external.Gs_plugin
INFO 2012-11-16 19:54:06.667 [main] Found plugin: com.chocolatey.pmsencoder.Plugin
INFO 2012-11-16 19:54:06.667 [main] Found plugin: com.sharkhunter.channel.CH_plugin
INFO 2012-11-16 19:54:06.729 [main] PMSEncoder: initializing PMSEncoder 1.6.2
INFO 2012-11-16 19:54:06.901 [main] PMSEncoder: script directory: C:\Program Files\Universal Media Server\scripts
INFO 2012-11-16 19:54:06.901 [main] PMSEncoder: log directory: C:\Program Files\Universal Media Server
INFO 2012-11-16 19:54:06.901 [main] PMSEncoder: loading built-in log4j config file: jar:file:/C:/Program%20Files/Universal%20Media%20Server/plugins/pmsencoder-1.6.2.jar!/log4j_default.xml
INFO 2012-11-16 19:54:14.888 [main] Registering transcoding engine: PMSEncoder
INFO 2012-11-16 19:54:14.888 [main] PMSEncoder: checking engine list: [pmsencoder, mencoder, tsmuxer, ffmpegaudio, mplayeraudio, tsmuxeraudio, mencoderwebvideo, mplayervideodump, ffmpegwebvideo, mplayerwebaudio, vlcaudio, ffmpegdvrmsremux, rawthumbs]
INFO 2012-11-16 19:54:14.888 [main] PMSEncoder: already enabled
INFO 2012-11-16 19:54:14.904 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO 2012-11-16 19:54:14.904 [main] Registering transcoding engine: FFmpeg Audio
INFO 2012-11-16 19:54:14.919 [main] Registering transcoding engine: MEncoder
INFO 2012-11-16 19:54:14.919 [main] Registering transcoding engine: AviSynth/MEncoder
INFO 2012-11-16 19:54:14.919 [main] Registering transcoding engine: FFmpeg
INFO 2012-11-16 19:54:14.919 [main] Registering transcoding engine: MPlayer Audio
INFO 2012-11-16 19:54:14.919 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2012-11-16 19:54:14.935 [main] Registering transcoding engine: MEncoder Web
INFO 2012-11-16 19:54:14.935 [main] Registering transcoding engine: MPlayer Video Dump
INFO 2012-11-16 19:54:14.935 [main] Registering transcoding engine: MPlayer Web
INFO 2012-11-16 19:54:14.935 [main] Registering transcoding engine: tsMuxeR
INFO 2012-11-16 19:54:14.935 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2012-11-16 19:54:14.935 [main] Found VLC version 2.0.3 in Windows Registry: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2012-11-16 19:54:14.935 [main] Registering transcoding engine: VLC Audio Streaming
DEBUG 2012-11-16 19:54:14.951 [main] Found VLC version 2.0.3 in Windows Registry: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2012-11-16 19:54:14.951 [main] Registering transcoding engine: VLC Video Streaming
INFO 2012-11-16 19:54:14.951 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO 2012-11-16 19:54:14.951 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2012-11-16 19:54:17.135 [main] Gs 0.50 using path C:\Users\jot\AppData\Local\Temp\universalmediaserver\gs_plugin tiny mode false init delay 3000 zero_fill false
INFO 2012-11-16 19:54:17.181 [main] Start channel 2.00
INFO 2012-11-16 19:54:17.275 [main] parsing channel file C:\Program Files\Universal Media Server\channels\1channel.ch version 0.14
INFO 2012-11-16 19:54:17.322 [main] parsing channel file C:\Program Files\Universal Media Server\channels\ard.ch version 0.20
INFO 2012-11-16 19:54:17.353 [main] parsing channel file C:\Program Files\Universal Media Server\channels\common.ch version 0.2
INFO 2012-11-16 19:54:17.353 [main] parsing channel file C:\Program Files\Universal Media Server\channels\Cuevana.ch version 0.2
INFO 2012-11-16 19:54:17.431 [main] parsing channel file C:\Program Files\Universal Media Server\channels\cuevanas.ch version 0.1
INFO 2012-11-16 19:54:17.447 [main] parsing channel file C:\Program Files\Universal Media Server\channels\eztv.ch version 0.1
INFO 2012-11-16 19:54:17.447 [main] parsing channel file C:\Program Files\Universal Media Server\channels\furk.ch version 0.37
INFO 2012-11-16 19:54:17.462 [main] parsing channel file C:\Program Files\Universal Media Server\channels\icefilms.ch version 0.51
INFO 2012-11-16 19:54:17.462 [main] parsing channel file C:\Program Files\Universal Media Server\channels\iPlayer.ch version 0.12
INFO 2012-11-16 19:54:17.478 [main] parsing channel file C:\Program Files\Universal Media Server\channels\kanal5.ch version 0.20
INFO 2012-11-16 19:54:17.478 [main] parsing channel file C:\Program Files\Universal Media Server\channels\Movie2K.ch version 1.31
INFO 2012-11-16 19:54:17.525 [main] parsing channel file C:\Program Files\Universal Media Server\channels\Movie2Ks.ch version 1.0
INFO 2012-11-16 19:54:17.525 [main] parsing channel file C:\Program Files\Universal Media Server\channels\muzu.ch version 0.1
INFO 2012-11-16 19:54:17.525 [main] parsing channel file C:\Program Files\Universal Media Server\channels\myp2p.ch version 0.31
INFO 2012-11-16 19:54:17.540 [main] parsing channel file C:\Program Files\Universal Media Server\channels\navix.ch version 0.40
INFO 2012-11-16 19:54:17.540 [main] parsing channel file C:\Program Files\Universal Media Server\channels\nzb.ch version 0.1
INFO 2012-11-16 19:54:17.540 [main] parsing channel file C:\Program Files\Universal Media Server\channels\picasa.ch version 0.1
INFO 2012-11-16 19:54:17.556 [main] parsing channel file C:\Program Files\Universal Media Server\channels\rtmpgui.ch version 0.12
INFO 2012-11-16 19:54:17.556 [main] parsing channel file C:\Program Files\Universal Media Server\channels\rtmpStuff.ch version 0.15
INFO 2012-11-16 19:54:17.571 [main] parsing channel file C:\Program Files\Universal Media Server\channels\siries.ch version 0.1
INFO 2012-11-16 19:54:17.571 [main] parsing channel file C:\Program Files\Universal Media Server\channels\subtitles.ch version 0.58
INFO 2012-11-16 19:54:17.571 [main] parsing channel file C:\Program Files\Universal Media Server\channels\svt.ch version 0.57
INFO 2012-11-16 19:54:17.587 [main] parsing channel file C:\Program Files\Universal Media Server\channels\swetv.ch version 0.12
INFO 2012-11-16 19:54:17.587 [main] parsing channel file C:\Program Files\Universal Media Server\channels\telia.ch version 0.1
INFO 2012-11-16 19:54:17.603 [main] parsing channel file C:\Program Files\Universal Media Server\channels\tpb.ch version 0.40
INFO 2012-11-16 19:54:17.603 [main] parsing channel file C:\Program Files\Universal Media Server\channels\tube.ch version 0.12
INFO 2012-11-16 19:54:17.618 [main] parsing channel file C:\Program Files\Universal Media Server\channels\tv4.ch version 0.22
INFO 2012-11-16 19:54:17.618 [main] parsing channel file C:\Program Files\Universal Media Server\channels\ur.ch version 0.11
INFO 2012-11-16 19:54:17.618 [main] parsing channel file C:\Program Files\Universal Media Server\channels\veetle.ch version 0.12
INFO 2012-11-16 19:54:17.618 [main] parsing channel file C:\Program Files\Universal Media Server\channels\veetles.ch version 0.1
INFO 2012-11-16 19:54:17.634 [main] parsing channel file C:\Program Files\Universal Media Server\channels\viasat.ch version 0.23
INFO 2012-11-16 19:54:17.634 [main] parsing channel file C:\Program Files\Universal Media Server\channels\watchseries.ch version 0.23
INFO 2012-11-16 19:54:17.634 [main] parsing channel file C:\Program Files\Universal Media Server\channels\youtube.ch version 0.40
INFO 2012-11-16 19:54:17.649 [main] parsing channel file C:\Program Files\Universal Media Server\channels\zattoo.ch version 0.23
INFO 2012-11-16 19:54:17.665 [main] parsing channel file C:\Program Files\Universal Media Server\channels\zdf.ch version 0.1
INFO 2012-11-16 19:54:17.712 [main] Configuration saved to: C:\ProgramData\UMS\UMS.conf
INFO 2012-11-16 19:54:18.024 [main] Using address /192.168.1.12 found on network interface: name:eth3 (Realtek PCIe GBE Family Controller)
INFO 2012-11-16 19:54:18.024 [main] Created socket: /192.168.1.12:5001
INFO 2012-11-16 19:54:18.227 [main] Checking shared folder: M:\Media\Video
INFO 2012-11-16 19:54:18.227 [main] Checking shared folder: W:\Torrents\dx
INFO 2012-11-16 19:54:18.242 [main] Checking shared folder: W:\Fighting
DEBUG 2012-11-16 19:54:18.398 [main] Sending ALIVE...
INFO 2012-11-16 19:54:18.476 [main] Using the following UUID configured in UMS.conf: 3840a4e5-d0f4-4c97-9103-db1d06487dfb
INFO 2012-11-16 19:54:20.953 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.1.16
INFO 2012-11-16 19:54:20.985 [pool-7-thread-1] Checking IP: 192.168.1.16 for Android
INFO 2012-11-16 19:54:21.094 [New I/O server worker #1-2] No IP filter specified, access granted to /192.168.1.7
INFO 2012-11-16 19:54:21.109 [pool-7-thread-2] Checking IP: 192.168.1.7 for WMP
INFO 2012-11-16 19:54:21.619 [pool-7-thread-2] Renderer WMP found on this address: 192.168.1.7
DEBUG 2012-11-16 19:54:21.634 [pool-7-thread-2] Starting ping -n 3 -l 64000 192.168.1.7
DEBUG 2012-11-16 19:54:23.646 [SpeedStats Failsafe] Stopping process: ping-0
INFO 2012-11-16 19:54:26.002 [pool-7-thread-1] Renderer Android found on this address: 192.168.1.16
DEBUG 2012-11-16 19:54:26.002 [pool-7-thread-1] Starting ping -n 3 -l 64000 192.168.1.16
DEBUG 2012-11-16 19:54:28.014 [SpeedStats Failsafe] Stopping process: ping-1
INFO 2012-11-16 19:54:28.014 [pool-7-thread-1] Address /192.168.1.16 has an estimated network speed of: 1 Mb/s
INFO 2012-11-16 19:54:31.103 [New I/O server worker #1-5] Checking shared folder: M:\Media\Video
INFO 2012-11-16 19:54:31.103 [New I/O server worker #1-5] Checking shared folder: W:\Torrents\dx
INFO 2012-11-16 19:54:31.103 [New I/O server worker #1-5] Checking shared folder: W:\Fighting
INFO 2012-11-16 19:54:31.118 [New I/O server worker #1-5] Node(net.pms.external.GsRoot) already has an ID=0$5, which is overriden now. The previous parent node was:RootFolder[[MapFile [name=Video, id=0$1, format=null, children=[]], MapFile [name=dx, id=0$2, format=null, children=[]], MapFile [name=Fighting, id=0$3, format=null, children=[]], VirtualFolder [id=4, name=Web, full path=0$4, ext=null, discovered=false]]]
INFO 2012-11-16 19:54:31.118 [New I/O server worker #1-5] Node(com.sharkhunter.channel.Channels) already has an ID=0$6, which is overriden now. The previous parent node was:RootFolder[[MapFile [name=Video, id=0$1, format=null, children=[]], MapFile [name=dx, id=0$2, format=null, children=[]], MapFile [name=Fighting, id=0$3, format=null, children=[]], VirtualFolder [id=4, name=Web, full path=0$4, ext=null, discovered=false], GsRoot [id=5, name=GrooveShark, full path=0$5, ext=null, discovered=false]]]
DEBUG 2012-11-16 19:54:36.095 [pool-9-thread-1] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 10 -i M:\Media\Video\20110911142342.m2ts -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2012-11-16 19:54:36.095 [pool-9-thread-2] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 10 -i "M:\Media\Video\Somebody That I Used to Know - Walk off the Earth (Gotye - Cover)(720p_H.264-AAC).mp4" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2012-11-16 19:54:36.142 [pool-9-thread-1] Attaching thread: ffmpeg.exe-2
DEBUG 2012-11-16 19:54:36.142 [pool-9-thread-2] Attaching thread: ffmpeg.exe-3
DEBUG 2012-11-16 19:54:40.603 [Buffered IO End Checker] Stopping process: ffmpeg.exe-2
DEBUG 2012-11-16 19:54:40.619 [Buffered IO End Checker] Stopping process: ffmpeg.exe-3
INFO 2012-11-16 19:57:18.741 [main] The server should now appear on your renderer
DEBUG 2012-11-16 19:57:28.756 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-16 20:00:48.498 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-16 20:06:48.499 [UPNP-AliveMessageSender] Sending ALIVE...
INFO 2012-11-16 20:11:47.000 [UPNPHelper] No IP filter specified, access granted to /192.168.1.12
DEBUG 2012-11-16 20:12:48.495 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-16 20:15:53.825 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-16 20:21:53.497 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-16 20:27:53.491 [UPNP-AliveMessageSender] Sending ALIVE...Re: Youtube.. what's the best way..
Ok, i got it working..
25 of my 100 favorites are now show.. but none of playlists..
