Xbox360 slideshow issue
hello guys
first thanks for UMS, you guys doing great!
i have little issue with xbox360 slideshow
it cant view .png image from ums... but i can view it with media server
what cause the issue ?
also if there a folder in a image folder, it wont show any image files...
so only can be view the deepest root, is that how it works (normal) ?
and i dunno if this cause and issue or not
but i mix my slideshow folder with both jpg and png
