iTunes Playlist Source Data Location?
netman63129
I'm having an issue where sometimes my iTunes playlists mp3 tag data is not updating on my UMS accessed using my PS3. Some playlists update, some take a while to update, and some never update (after changing mp3 tag data). I've deleted the UMS database but the old playlist mp3 tag data is still repopulating. I'm curious where UMS is pulling the iTunes mp3 tag data and if I can force an update?
netman63129
Re: iTunes Playlist Source Data Location?
The file that iTunes appears to use to populate the playlists is located at USER>My Music>iTunes>iTunes Music Library.xml. Of course, the mp3 tag data is correct in this file. This means that UMS is reading the data from another location...where? Also, the incorrect tag data is never read by iTunes because I fix them before loading the MP3s into iTunes. The only program that sees the incorrect data is Windows Media Player but I've also cleaned out this database. There must be a cache someplace but it is still a mystery
